95 GT on 3 performance turbo build
alex302
alex302
Well the engine bay is done. Got it started tonight and it is so rich it burns my eyes, wide band just sits in the red, tuner will have to take care of that. Just happy it's running
alex302
alex302
well the car is all back together. I'm having lots of issues with the v bands on the cross pipe and the ball and socket in the middle they leak like crazy. it looks like the cross pipe is to short, i tighten the clamps and the ball socket leak,i tighten the ball and socket in the middle and the v bands leak. i think it has to do with my trickflow heads they are a little taller and wider then stock so the cross pipe is to short. i am to take the pipe to a exhaust shop and have it lengthen.
alex302
alex302
Well the car is done just came off the dyno and at a 7psi it made 404hp and 432tq the cars great. very happy with the numbers. the injectors are summit racing 42lb.
Slykin
Tyler, Texas
Is that to the flywheel or RWHP? Not very familiar with the output of these setups. Looks real nice either way.
alex302
alex302
Rwhp.
Can any one help me fine a 12 volt vac pump setup for crankcase pressure.
94cobra94
i have a 94 cobra just got my kit got all the hot side on did you have any problems with sway bar hitting v band on drivers side header to crossover pipe...and did u just drill and tap the oil pan and permatex the sh*t out of it? the fitment seemed pretty good with my kit
JStang98
Apex NC
Somehow missed this thread, those are some pretty impresive numbers for 7 psi, kinda makes me consider one myself, what else do you have done to the motor?
94cobra94
i am having problems with my downpipe and my y pipe to cat back connector..did you run this setup on yours there is no way i can get mine to work think the v band parts got welded on crooked cause then i bolt it all up the catback will never line up for me.... i ended up shimming the sway bar down a little so it didn t hit v band on headers..only problem now is that downpipe to catback connector gonna call mike at on 3 tomorrow see what he says
alex302
alex302
Sorry I have not posted anything new. Well after I fixed my exhaust leaks I had some boost spike and pushed out my graphite head gasket at 10psi. I added a second 38mm wastegate on the drivers side to control boost.
alex302
alex302
I bought some cometic 3 layer head gaskets.
thorco3
IN
sweet. bummer about the head gasket.
I really need a set of heads, my car hates the e7's
alex302
alex302
i have a set of trick flow heads and they are great right out of the box, i made 300hp before the turbo kit with them..
Overused_03
