Sure do! Ill send a link for sequence procedure.
The cam caps are in in.lbs. just tighten them by hand will be fine, but keep in mind its a stretchy 6mm bolt and dont need much. Most folks dont have an in.lbs. torque wrench, but in case you do 70-100in.lbs. is the spec and to boot their is a sequence. No need to pay much attention to sequence here, but is good practice. I will say the torque spec is a bit loose for my feel. I always hand snug the bolts.
The head bolts are sequenced 30ft.lbs, sequence 90° turn, and then sequence loosen 1full turn. Repeat this scenario again but dont loosen. When finished add a final sequence, another 90° turn. Hold on to the engine stand with your foot. A breaker bar and proper socket helps. By proper I mean 6point for 6point bolt or 12point for 12point nut...
Be sure to thoroughly clean the engine deck surface before laying a gasket down. Take a clean shop towel with rubbing alcohol for final prep cleaning.
