Bryan's 96 GT Vortech Build
BMAC96GT
BMAC96GT
Virginia
No real update, just chipping away at smoothing this engine bay. The amount of welding and grinding I've done is ridiculous....mainly grinding, to clean up my shitty welds lol. Also laid the Scott rod panels in. They came with lines in them, which I wasn't expecting. Do y'all like the lines or no? I'm still getting used to it...haven't decided whether I like it or not.
BMAC96GT
BMAC96GT
Virginia
[MENTION=20210]lwarrior1016[/MENTION] glad you like them. I expecting smooth panels so these will take some getting used to. Not looking forward to welding them in at all though
BMAC96GT
BMAC96GT
Virginia
I've really been doing a lot of thinking and I may end up making my own engine panels. Im not necessarily the happiest with these panels, and after the cutting, trimming, and fabbing that Im going to have to do with these panels to make them fit, I may as well make my own, and make them with some thicker material. Since I like the flat look and not the panels that fit the contour of the engine bay, I really just need two pieces of flat sheet metal.
Kind of undecided
BMAC96GT
BMAC96GT
Virginia
I ended up fabbing up my own engine panels. I wasn't that happy with the Scott rod panels. Nothing wrong with them, I just wanted thicker material. Scott rod panels are probably 22-24 gauge if I had to guess. I got a sheet of 18 gauge and went to work
Tacked in.....
And where I left it yesterday
Also got a March power steering reservoir off eBay for my relocation. The quality on this piece is off the charts. I plan on mounting it in the fender well with the fuse box
Also got my fuse box bracket mounted in the fender well. I went ahead and welded a 16 gauge piece of sheet metal to the back of it for more rigidity and threaded the original screws in through the engine bay
Also determined that I would have too much time and effort into polishing the Vortech so I found a guy up north that was reasonable on price so he got the nod. I have two pieces done right now, the compressor housing and the Anderson power pipe I bought used off corral
BMAC96GT
BMAC96GT
Virginia
[MENTION=16230]98snakehorse[/MENTION] lol thanks man!
Dude, you are seriously making me think about some home made panels. Now I hate you........
Really though, this thing is moving along nicely and looking awesome too. Great job on the panels and I think you made a smart move sending those pieces off to get polished up, they came out fantastic.
BMAC96GT
BMAC96GT
Virginia
[MENTION=20210]lwarrior1016[/MENTION] haha it's just as simple as it looks!
And yeah I'll just be glad when I can get done with all this metal work and body work and get some paint on it.
BMAC96GT
BMAC96GT
Virginia
Got the drivers side done tonight. Extremely pleased with how it turned out. Really glad I went this route. Need to finish measuring the passenger side for the power pipe hole, cut it, tack the panel in, then get ready for filler
1bad95
Looks great man! I would love to do what your doing to mine! The inner fender panels looks really nice!
Sent from my XT1585 using Tapatalk
BMAC96GT
BMAC96GT
Virginia
[MENTION=11461]1bad95[/MENTION] be glad you're getting ready to drive yours! I still have a long way and a ton of hours to go
1bad95
I just posted on Nick's build thread about the vortech belt. 113 is stock length for ours with 3 bolt tensioner, the 108" is for the new edge cars with the 1 bolt tensioner. Wanted to post it here too so you def saw it.
BMAC96GT
BMAC96GT
Virginia
Ah! Somehow just saw this. I appreciate the info man! [MENTION=11461]1bad95[/MENTION]
BMAC96GT
BMAC96GT
Virginia
Guess I can give a small update. Finding time to work on the car has been tough. Still putting in as much time as possible. Finished all metal work, got the car on the ground, and am currently doing body work now
BMAC96GT
BMAC96GT
Virginia
Small update...getting some body work done in prep for paint. Got the top of the rad support close. Little more work there then I'll start sanding on the engine bay panels. Here's a little before and after of the front of the car after body filler and a few coats of high build primer
Before...
After
BMAC96GT
BMAC96GT
Virginia
Body work continues to consume my life.
Quick question...you guys think I should go ahead and shave these holes on the frame rail while I'm at it or just leave it alone cause they're basically out of sight? Let me know your opinion!
And here's a few pics after a coat of high build primer
T's Convertible
