Cams
duff daddy
Got Trq said:
Sweet thanks for those
They are good, however we used the correct tools and made our own cam lock down tool. FYI your OCT cam lockdown tool will NOT work with some a.m cam profiles such as bullitt.
duff daddy
MadStang
MadStang
Escondido, Ca
a.m profile? what does that mean?
JDwhite98gt
Wow makes it seem like a breeze lol....mechanically its not that hard; more of a mental hurdle you have to overcome.
duff daddy
aftermarket cam profile. The shaft between the lobes on Bullitt Race cams are a different diameter then the OE Cam stalks. We checked in several places from Bullitt to OE NPI cam and 4v cams. (both 2v and 4v tools)
duff daddy
With the help of a good frend we degreeded my cams at least 7-8 times between checking setting, rechecking and resetting. Once we got to where we wanted to be (106* centerline) then put it all together torqued Cam gear bolts to spec and then rechecked several times.
MadStang
MadStang
Escondido, Ca
wut about regrinds?
duff daddy
MadStang said:
wut about regrinds?
You need to measure the diameter of camshaft between lobes. If they are just regrinding the stock cams to a different profile then i would assume the otc tool would work (basically using the stock cam stalk)
MadStang
MadStang
Escondido, Ca
Duff Daddy said:
MadStang said:
wut about regrinds?
okay, yeah my friends car is what is based my cams off of. He did his with the OTC tool. he made 290/310 to the wheels on his bone stock 03 saleen (n/a). He did no degree the cams, he did not change the springs, he could have made more power past 6k as the power band was still climbing (it's a blower cam). he made 470whp when he put the Procharger on. He's got HP 292 cams, I went with some with a little more of an aggressive idle.
http://www.youtube.com/watch?v=rfZj_W2sVt8
duff daddy
MadStang said:
Duff Daddy said:
well if he didnt degree them, then you wouldnt need the OTC tool.
but to change springs?
If the cams were already out you could just change the springs with the heads on the motor with a spring compressor. He prob used the OTC tool to hold the cam from bumping over, thats the only reason I could see him needing it.
vermilion
maryland
free horsepower varies. im not referring to just lining up the marks of keyway or cam gears. i mean double checking the cam cards specs.
MadStang
MadStang
Escondido, Ca
I texted him and asked, here's his response:
You use the tool to compress the springs so you can install the followers underneath the cam after you time the engine. It makes timing way easier with no tension on the cam
duff daddy
He used the OTC tool that looks like this
This goes between the cam shaft and the top of the valve spring. compresses the valve spring which allowes you to remove the follower, the 2 keepers and then valve spring and retainer follows. If you look at my how to at the top for Valve seal repalcement, this is all explained, and a demo of how it works.
This is the OTC tool of which i was talking about .
OTC Ford Cam lockdown tool.
MadStang
MadStang
Escondido, Ca
oh yeah I should have mentioned it's OTC 7928. do you think they have those at autozone to rent so I don't have to buy one?
MadStang
MadStang
Escondido, Ca
Response from Jim Cushman:
That would be news to me, never have seen or heard that.
On October 5, 2010 at 4:15 AM Brett Madsen <[email protected]> wrote:
> Hi Jim,
> I saw the 2v cam gear kit for press on cam gears and have a question. I've been told that if I used the Romeo gears on my 99 Windsor, the spacing will be off on the trigger gear and crankshaft sprocket. is there truth to this or will it be a direct bolt-in? Thank you for your time!
> Regards,
> Brett Madsen
Jim Cushman
www.cushmanmotorsports.com
http://stores.ebay.com/J-J-Performance-Center
