I am trying to figure out if I have 302 heads or 351 heads because I have a cobra upper and lower intake. And I want to know if a cobra intake will work with 302 heads or only 351 heads. HELP GUYS!!!!!
Thanks in Advance
Thanks in Advance
I had a fox with 351 heads and a gt40 upper/lower intake. Why would they be any different? the intake you have theoretically should work on both 302/351 heads.
the heads are the same with the only real difference being the bolt hole diameter. either way the cobra manifold will bolt to it unless you found like the 1% of them for a 351. which i HIGHLY HIGHLY doubt.
