CompOrangeSN95
This is interesting on so many levels. I am curious how you like the IRS over the SRA in the corners. Also, that diffuser sure loooooks sweet. I see that you have or plan to have a fuel cell. Are you plan on cutting into the trunk and have the fuel cell sit higher than the OEM tank? and since you are making a belly pan, are you planning on reworking the bottom to sit flat? or are you planning to make it lower and keep the bottom the same?
I'm curious about the IRS vs watts link as well honestly. I've driven an SRA GT500 with a watts link and a decently well setup suspension more times than I can count, so I have something to compare it too (despite the almost 1k difference in weight). The IRS should stay more stable in bumpy corners, but on smooth pavement I'm sure an SRA watts link setup would be equally as fast. The plan for the belly pan is make it level with the bottom of svo skirts and follow that throughout the car. I will likely machine standoffs that mount to the chassis, making it easier to keep the whole thing flat. I need to plan some spots for naca ducts for rear brake cooling, diff cooler, and trans cooler.
P.S. I may be copying your splitter... it looks fantastic.
