Coyote 5.0 Engine Swap....in a Thunderbird
OxmanWI
Milwaukee, WI
This is one of my favorite forums to get info and help from awesome members, thought I'd share my Coyote swap project. I know it's not a SN95 but a Ford non the less. Using a 2013 Mustang Coyote with 26K with Ford Racing controller pack. I ready have a built-up 4r70w with a Circle D TC, Lantech MVB, Hurst shifter. Alternator and power steering bracket kit from Power by the Hour. Keeping the IRS with 4.10 gears. Coyote flange MN12 kooks headers. Brand new AJE tubular k member. Dyno tune sometime this sping. Lots of pictures to share!
OxmanWI
OxmanWI
Milwaukee, WI
Test fit
I bought turbo exhaust flanges from JEGS and the diameter of the port holes were 1.75". My MN12 Kooks headers have the 1.50" primary. I bought a steel tube from a welding shop with an OD of 1.75" and an ID of 1.50" perfect, only $5, they were going to scrap it. I cut the steel tube into 8 rings to have welded in the flange so I could match the 1.50" primary. I than had the headers welded on top of the flange. I just got them back this week and did a test fit, they are golden. The driver side is a little tight but it will work. I also had a extra O2 bung welded in for my wideband. So they are done for the most part, I just got them back from the machine shop. After all the welding, the heat will warp the flange, so I had them flatten the mounting side. Next week I'm having them ceramic coated.
The oil pan.
These are for Cobra rotors in the rear. I also did a Mustang 4.50 hub swap and bought new UHMW knuckle and lower arm bushings for the rear. New Cobra rotors and pads, braided brakes lines, Reman Corvette calipers, Reman rear T-Bird calipers and wheel spacers for Mustang rims.
Man these are cool! Can't wait to have these in. The speedo is GPS, no VSS to plug into. Turn signal and flash built in. Made in the USA.
OxmanWI
OxmanWI
Milwaukee, WI
Used some silly puddy to see what the clearence from the bottom of the sump.
2011+ Mustang 5.0 the oil adapter
Headers and oil pan, coming together!
Since this is a full manual I have to wire buttons for the TC lock up and overdrive. I'll probably wire the red button on the hurst as the overdrive and put a button on the center console dash for the lock up.
I bought this 1/4 steel plate 12x4" to mount the hurst shifter. Drilled the holes and mounted nice a strong.
I had to cut a little tab out in the front, not bad.
neverenuff
Nice build! High quality parts too. Can't wait to see the finished product, is this going to be a sleeper or track car?
Sent from my SM-N900V using Tapatalk
hotmustang95
Boynton Beach FL
Holy hell, I love where this is going. Big fan of the T-Birds. Had an 84. Blew the engine and had to get rid of it being I didn't know how to work on it. If only I had it now it be a bad mofo. Hats off to you friend.
OxmanWI
OxmanWI
Milwaukee, WI
Thank you I was just looking over your build thread, that is bad ass mustang, I like the cowl hood. Just a street car. I was going to ask, did you make the power steering bracket?
neverenuff
Thanks for the kind words OxmanWI, I used PBTH power steering pump bracket, the reservoir bracket is a custom aluminum piece that attaches to the coyote's timing cover and fits pretty good. I did not want to lose PS as this is my grocery getter (daily).
Your manual shifted auto threw me off as far as a street car. Ive seen a 5.0 swapped BMW but not a late model T-bird. Keep up the great work!
OxmanWI
OxmanWI
Milwaukee, WI
I got the headers back from ceramic coating. The valve covers back from powder coating. I'm hoping mid May or June 1st for a start up.
g36 monkey
Orlando, Fl
Dude this is so awesome!
This build will probably help several Mustang guys drop in since it's still ultimately a 4.6 to 5.0 swap.
I love it. Great parts list, great progress so far. I wish I could see it in person!
Those headers turned out great! To bad they are tucked away. Ive been poking at a set of coyote headers evolving them into 5.4l swap headers. Your build has inspired a few ideas for me. Thanks
evilcw311
Most Evil Member!
Louisville, KY
Looks awesome!! I had 2 built supercoupes and would love to of done a swap like this.
Thunderbirds just ride so nice and smooth compared to our stangs
OxmanWI
OxmanWI
Milwaukee, WI
Little update:
A few weeks ago I got the transmission back.
The engine and transmission are in the car for good, I did that a week ago or so.
Today I was able to put in the headers and starter. Tomorrow I'm hoping to start more on the wiring and install the radiator and fan. More to come!
Holy smokes! How did I miss this thread!?!?
You are doing some awesome work with this thing. Great job man, keep us updated.
jeanfltns01
