My first guess would be the wheel bearing. Good thing about our cars is that the wheel bearings are cheap and a breeze to replace
Ever changed your ball joints?
The squeaking noise is made by the metal pieces that hold your brake pads in getting weak, I had the same problem on my GTReplaced the front wheel bearings, wheel no longer moves when grabbed at 3' and 9'. However still squeeks, but not when brakes are applied. Who knows. Installed the J&M lcas as well, did everything in a record 2.5 hours. The lcas are great for dd, had the same set on my old GT.
However the best mod that I did was apply a liberal amount of velcro (the soft side) behind the radio/ shifter trim area. Stopped all the rattles and creak... I think I used around 6ft.. :shocked:
Anyways, didn't take any pictures of course! lol.
Next on the list is a set of long tubes, but the MACs are on indefinite back order..
Negative! The wilwood calipers do not have those, I do know what you're talking about though.The squeaking noise is made by the metal pieces that hold your brake pads in getting weak, I had the same problem on my GT
Yes! I can get pictures if you're interested...To clarify, you basically stuck the soft sided Velcro behind your center trim on the shifter/hvac/radio trim? Around the edges or something?
Doh! I forgot you had upgraded to the WilwoodsNegative! The wilwood calipers do not have those, I do know what you're talking about though.
I think ttocs did a wire tuck recently maybe he'll chime in. As far as the LT's you might want to check out Kooks or ARH as they are quality parts that you don't have to remove to do a clutch!
Your brake/wheel combo is so sexy![]()
Thankya! I have been considering going with gloss black rovos durbans opposed to the satin gunmetal.. thought?
