.::Cpotts Mach Won Build Log::.
BMAC96GT
Virginia
My first guess would be the wheel bearing. Good thing about our cars is that the wheel bearings are cheap and a breeze to replace
C
Cpotts13
Biloxi, MS
Ever changed your ball joints?
Well I lifted up the car and was able to shake the wheel with my hands at 3' and 9' on the wheel, but not at 12' and 6'. Ball joint boots have never been replaced, the car has 46k on it and the boots are in good condition still. Fairly confident it is the wheel bearing.
BMAC96GT
Virginia
I've had wheel bearings and ball joints both go out. Wheel bearings caused a squeaking noise while driving, anytime the wheels were rotating. When the ball joints go out they squeak whenever the wheels are turned.
C
Cpotts13
Biloxi, MS
Replaced the front wheel bearings, wheel no longer moves when grabbed at 3' and 9'. However still squeeks, but not when brakes are applied. Who knows. Installed the J&M lcas as well, did everything in a record 2.5 hours. The lcas are great for dd, had the same set on my old GT.
However the best mod that I did was apply a liberal amount of velcro (the soft side) behind the radio/ shifter trim area. Stopped all the rattles and creak... I think I used around 6ft.. :shocked:
Anyways, didn't take any pictures of course! lol.
Next on the list is a set of long tubes, but the MACs are on indefinite back order..
BMAC96GT
Virginia
To clarify, you basically stuck the soft sided Velcro behind your center trim on the shifter/hvac/radio trim? Around the edges or something?
Milehigh JDF
Colorado
The squeaking noise is made by the metal pieces that hold your brake pads in getting weak, I had the same problem on my GT
C
Cpotts13
Biloxi, MS
Negative! The wilwood calipers do not have those, I do know what you're talking about though.
Yes! I can get pictures if you're interested...
C
Cpotts13
Biloxi, MS
Life Update:
Actively looking for a nice set of long tubes (preferably used), other then that just a few maintenance things planes. Redo my calipers and rotors, and hunt down a few rattles on the inside. Head my TOB chirp for a few seconds the other day, with the clutch disengaged.. Will be monitoring that closely..
I would like to snazz up the engine bay by doing a wire tuck, battery relocations, new cam covers and cop covers... Need a little guidance on the wire tuck though..
Sinned83
MA
I think ttocs did a wire tuck recently maybe he'll chime in. As far as the LT's you might want to check out Kooks or ARH as they are quality parts that you don't have to remove to do a clutch!
C
Cpotts13
Biloxi, MS
I am really aiming for a set of MAC's. I have heard that the trans will clear them.. Thoughts?
Sinned83
MA
I heard the mac's work tight but they work. Fitment isn't as good as the nicer sets
C
Cpotts13
Biloxi, MS
Just ordered a set of Ceramic Mac lt headers, Mac o/r x mid pipe and Ford Racing header gaskets. Grand total: $680 Shipped. PSYCHED!
C
Cpotts13
Biloxi, MS
I'm still interested in doing a wire tuck, not a major one, just hide things like fuse box etc... Any tips would be or links would be appreciated.. This weekend should be fun installing my headers... should be here Wednesday..
