Engine build dilemma
Superfastgt
So I was in the process of tearing down my 2v 4.6 on my 98 GT for a PI swap with stage 3 Comp Cams when I decided I had it swum to the block, I might as well go all out. So my dilemma is, do I go ahead and do forged internals and a blower or throw in a 351 stroked out to a 408? They are both expensive. What are some opinions on the pros and cons of each? I would love the 408 but am afraid it will be too much to deal with as far as wiring, etc. For the first option is would need a forged kit or stroker kit and a shop to install it then I need a supercharger for the second option I would need the crate motor, new trans and other computer or wiring components. Note: this is my bracket racing car and will basically be trailered to races and shows. Not worried about being street legal. Thanks for any advice you can give.
Win
Kennesaw, Ga
351 can work easily stroked to a 408
wiring shouldn't be too bad really.
99GreenStang
Transmission you have now will work just so you know . Why not put a 514 in it ? There's no replacement for displacement.
Hope this helps God Bless!
99GreenStang
If you do the big block you do need new Trans though just to add that in
U Might want to price it out BOTH ways to help u decide and review the pros/cons.
MustangChris
Aurora, CO
id stay away from the 408. [MENTION=10188]white95[/MENTION] can give some insight on big-cube builds. But if you do go that route, id suggest a stand-alone or a carb set up.
white95
Apex Junky
Prairieville, LA
Sell it and buy a Coyote 5.0/Terminator/GT500/Roush/Saleen or some other "already fast from the factory" ride.
white95
Apex Junky
Prairieville, LA
However... Keep a modular in your modular... Hell, build your 2V up... Ask [MENTION=10532]MadStang[/MENTION] how much fun his 388 rwhp 2V is or [MENTION=10730]duff daddy[/MENTION]... 4V swap wouldn't be terribly hard but I'd go with a terminator swap over all....
Less wiring...
such direct swap...
much fast...
MadStang
Escondido, Ca
Less wiring...
such direct swap...
much fast...
Duffy can't tell you, his car doesn't drive :look:
D3VST8R96GT
Marble Fall, AZ
You can get coyote motors out of f150s real cheap. Only differences as far as I know are cams, intake, tuning, and compression. Also apparently something about oil cooling.
http://www.ebay.com/itm/like/310953285814?lpid=82
The only difference is half the motor Lol.
That is a great price!!!! I think the market is flooded.... that will hopefully bring down 4.6 4v prices..... still cheaper to 5.3 LS
The D3V
Pete@FTR
Preferred Vendor
Rocklin, CA
The D3V
Haha you're right it sounds like a lot, but the parts are just slightly different still very similar.
I was surprised about the price too, apparently its pretty easy to get a hold of these motors used.
chasingomas
