Eveyln's Resurrection
Ineedav8
Ineedav8
South Florida
Reflector less corners prepped to be black also attempted to fix my drivers side exhaust leak
Ineedav8
Ineedav8
South Florida
Header flange is bent so no bueno nor care just mean i have to hustle and build the 4 valve but recently Ive been working on these prepping them for life once again polished/painted barrel powdered or painted face and polished lips flush mount valve stems and some form of center cap
Need to decide on a color though...
Ineedav8
Ineedav8
South Florida
Trying to avoid reading build threads etc and just do things differently that make me happy but i still like to throw up some progress but got my relay harness in and installed now i can flash all the mall crawlers with there led bars on at night and decided to go a different route with choice of wheel color and some interior work here and there just fixing an abundence of problems but anywho heres some pictures
I could finally slap that sticker on now lol
And just upgrading my underhood lighting from 3 small leds to 24 leds in total (using a small strip.) Now I have a reason to make it look presentable under there now that i can see lol
Ineedav8
Ineedav8
South Florida
Well here I am now
As well as popping the tubular k member and solid motor mounts in
As I wait for this bundle of happiness as well as my 3 month long wait for decals,plate frame and lanyard hopefully it'll be back together before the next cars and coffee
Pleasanton/Hayward, CA
Did you ever think of continuing the white theme you have going on and doing white with a polished lip?
OR maybe a black gloss lip and satin bronze face?
Ineedav8
Ineedav8
South Florida
I thought of doing the entire rim in a sunken treasure color that looks black untill the light hits it at an angle but knowing how much i like the white they'll probably get piwdercoated a matte white
Ineedav8
Ineedav8
South Florida
Drivabillity issues anyone? Lol all of them have cracked caps
Painted more goodies dont plan on using the oem drivers side coil bracket but wanted to paint it lol plan to relocate them to on the firewall behind the intake also i cracked the coolant passage on the intake so i had to improvise so i started by hacking the passage off entirely and tapping it for a brass fitting threw it all togther with some locktight and some epoxy i dont think i should ever have a leak again i just have to smooth it out a bit and repaint it
Ineedav8
Ineedav8
South Florida
Found a decent driver side taillight and decided to grab it also found a mark 8 fan pulled it to find out it was cracked and broken
Oh well my timesert tools came in today so on the head stays because screwww all that and just reassemble the car and maybe decap the 19lb injectors or swap to 24lb injectors
Ineedav8
Ineedav8
South Florida
Back on the ground again need to put togther the other valve cover and some little things then the timesert install on the motor getting a borescope and slapping magnet in the cylinder for a hour untill i get all of the shavings lol
Staff member
Lawrenceburg Kentucky
I use an air hose black taped to a shop vacuum hose to get the big chips after useing the first tool, before installing the sert. Dont root in to much about the smaller shavings. When aluminum is that thin, that small, first compression evaporates it. Most of the chips are to big to slip between the piston and cylinder wall. In other words, timesert designed a great tool to keep the chips big. A bore scope is a great idea looking for other types of damages that may have happened. Timeserted 5.4l have ran years with not much thought about the aluminum shavings. They timsert it and then fire up! Even though the instructions were to evacuate the chips.
Ineedav8
Ineedav8
South Florida
Yup bought a helicoil kit but didnt like the idea being the motors really healthy just old so decided to fork out the hundreds and buy the kit. I'll post up how it goes I'm excited to have my car back ! In the instructions it says to use a metal bonding heat resistant material should i use red lock tite or another adhesive?
That spoiler is right at home on your car
Thanks man needs some love but im enjoying it!
Ineedav8
Ineedav8
South Florida
Thats intresting. My kit came with threadsealer....like'ish something. Ill double check when at home.
Yup it says to use a "jb weld or other heat resisting material" it's to late tho heads already drilled and tapped need to clean the shavings the best i can borescope helps alot.
Love this shot [emoji106]
Thanks man may end up on some rpf1's offered the fr500s for trade
JerZeyStangz
Northern NJ
Back on the ground again need to put togther the other valve cover and some little things then the timesert install on the motor [emoji21] getting a borescope and slapping magnet in the cylinder for a hour untill i get all of the shavings lol
I love this shot as well! Reminds me of my car [emoji51]
Ineedav8
Ineedav8
South Florida
Some MacGyvering and shes clean and timeserted
Also not pictured is my redneck brake clean tornado tapped a smaller hose on the shop vac then cut to slits into the hose and put 2 smaller hoses in one to a can of brake clean and one to the blow gun off the compressor very dangerous yes but effective hellll yes lol
