Gray 98 gt buildup hopefully
MoMustangs
SoCal
Are you sure the clutch isn’t slipping? Might as well check the fluid level and condition while you’re poking around under there.
I'll check it but I changed it around 2 months ago, and it doesn't leak, clutch has like 20k on it, its not slipping as far as I know
MoMustangs
SoCal
Never figured out why my transmission was smoking but i got an update
I got the car some upgrades for the suspension, MMS non offset tubular front control arms, qa1 rear control arms, and some pedders xtreme coilovers for the car, i got one side done so far, and it looks like ill need a new PS rack and those front fenders will definitely need to be rolled, luckily we got a fender roller
joe65
good stuff! too bad you didn't get to do the k member and get the big hunk of stock k member out of there.
MoMustangs
SoCal
I actually do plan on doing that someday, money is limiting me for now, ill probably wait till i have to pull the engine to do that
joe65
like it. if i didn't say it before, those wheels look great on that color/body.
MoMustangs
SoCal
So it took a little longer then I thought, I ordered rear spring isolators because the old ones were shot. I've been driving it around for some time now like this20210620_181100.jpg20210707_163723.jpg20210620_181113.jpg
MoMustangs
SoCal
Now for the bad news the t45 is on its way out every gear causes a really bad driveline vibration except for 4th gear(friend believe this is because 4th is direct drive?), I think I'm just going to get a tr3650 to replace it. After installing this suspension and a socal heat wave with no ac I don't think I want this as my daily anymore
My brothers foxbody was in a hit and run, he was about to primer it to get painted eventually. He didn't have full coverage and between the front and read subframes there is 2-5 inches of difference, rear Axle was broken and broke a wheel, it's already been taken to a foxbody junkyard. It's sad but we might get a hardtop before they become unaffordable/unjustifiable to purchase for us ever again.
07GtS197
Fort Myers, Fl
That’s shitty. I hate people that do that. I get being scared but come on you just fucked someone’s car up and you run? That pisses me off.
You can swap in a tr3650 but youd need a speedcal which are unobtanium right now.
MoMustangs
SoCal
Didn't know that about the speedcal, what Is it? I'm gonna guess speed calibrator?
and where do people get them from?
07GtS197
Fort Myers, Fl
Dallas mustang used to make them, I guess it’s possible to use some sort of converter to modify the vss signal. It’s a shame they stopped making them but it seems the sn95 market is drying up.
Makoto
Houston
I really wish someone made us some nice looking wider fenders in front. I had to modify mine extensively to get them to flare enough to fit the most common wheels in the front. that GT is CLEAN tho, im a little envious :D
Suprasuavy
