New Track Times!
white92
justinschmidt1 said:
white92 said:
White92: you dont even make sense...you say he would have to make 450 rwhp...well 05+ gt's with blowers and bolt ons can easily make 450+ rwhp.
with 10 psi and any kind of bolt ons or meth/intercooler 05+ gt's make over 450 at the wheels
what dose that have to do with his car ?
I was referring to the 07 GT that only trapped 96 mph
[/quote] so you saying that a 450whp car only trapped 96mph ? and a yes 300whp car can go 11's but not a car that weights 3440lbs. at like 2300lbs it could
WarHorse
Wrong again, 3000+ lb SN's can do low 12's with less than 300 hp. a local GT does 12.1 with a race suspension NA (meaning no Nitrous) dyno proven 277 rwhp on 28" ET streets.
idk the elevation of our local track but i know a couple GT's runnin well NA with bolt ons, just search you tube and you'll find several videos of 4.6's runnin 12's on bolt ons.
justinschmidt1
[/quote]
Are you special?
Seriously?
That 07 Gt with a vortech should make anywhere from 400-500 rwhp at sea level...I have no idea what he is making in the side of a mountain.
Im saying that at sealevel that car should make well over 400 and trap 115~ or so
You must be used to hondas with no torque...theres LS1 Camaros tha run 10s at 130 mph with 400 at the wheels.
The car that runs 12.2 @ 113 with like 250 rwhp weighs in at like 2800 lbs, with a driver and gas its a 3000lb+ car
HP is not all that matters.
Take this for example: just say all these cars weigh 3000 lbs
a 400 hp honda runs 12s/13s, 400 hp mustangs run 11s/12s, 400 hp ls1s, run 10s/11s
You see the trend here?
400 hp in a 2l is not = to 400 hp in a 4.6l just as 400hp in a 4.6l mustang is not= to 400 hp in an ls1
more cubic inches generally means more torque and power under the curve
Hondas thrive on being gutted oversized go carts.
Put that little 1.8l in a normal car, like one that doesnt weight 2300 lbs. Add 1,000 lbs to your car and watch your 12.9 turn into like 14.9
1996slowstang
O I see what you mean.
I believe theres a differance in the power it takes to go from 14.5 to 13.1 and 13.1 to 11.5.
But if you had your car exactly the same as matts car and cut 1.6 60 foots and were spraying a 100 shot I would bet your car could run damn near 11.5
I guess low 12s/high 11s would be more reasonable.
Theres a guy with a stalled auto00 GT over on corral that makes all of 240 rwhp with complete drag suspension, weight reduction, gears, etc.
Point is, his car runs 12.2 @ 113 mph with a 1.6 60 foot and no more than 300 hp. He has only bolt ons and full exhaust.
Its not all about power.
I really have no idea what his car would do....maybe he will run it at sealevel on day so we can find out.
I just think that is pretty fast for such little work done to a npi car something to look foward to I guess
justinschmidt1
Im not even sure but suspension goes a long way....
He has the setup and with his mods and 100 shot he should be around/over 300 rwhp...so with some weight reduction he should definately be able to hit 11s with a drag setup and his 60 foots.
WarHorse
i know his 60 foot times were very low, so im assuming he already has a decent amount of suspension mods. the faster you are outa the hole, the better your times are going to be, i did 14.8 stock and only had a 2.4 60 foot.
alleghenyamerican
