Moar updates on Project Cherry Bomb!!! Today I had assistance for the X, we tackled the dreaded door window project. I can tell all of my faithful followers this was one job we had both dreaded... We were nervous about possibly scratching the new glass or even breaking it in a thousand little pieces!! First off we got the glass out the huge cardboard it was packed up in, and I must say LMR does a really good job packing glass up!! Mine was packed up with plenty of air pockets and cardboard to prevent and breakage, so if your considering getting glass from them I can recommend it!!
Also used some 220 grit sandpaper to clean off any old plastic that was stuck to the old guide rod and gave it a shot of carb cleaner to clean it up good and let it dry. The actual install I don't have any pics of cause we both had our hands full so I'll just have to give you a play by play, and remember this is a foxbody, so there may be differences with your sn-95's... We did hook up the power window so we could raise and lower the Trac as needed, starting out we had the front of the glass angled down and the back up with the Trac about 3/4 of the way up and then we're able to slip the Trac into the window. Then came the guide rod. For that we had to even the window out and lower it most of the way down so we could spread the door apart enough to slide the guide rod down between the inner door and the glass while also feeding it thru both of the guide bushings in the glass holder. I'll have pics in a minute to show what I'm talking about. The tricky part here is the top of the guide rod has a stud on it that makes it hard to get down between the glass and the door and it will try to twist on you at the same time. The other part that makes it hard to get it all the way in, on the bottom of the guide is a stud the comes out the bottom of the door that you have line up as well. Getting the bottom stud lined up was probably the hardest part of the whole job honestly.. it was a blind hole and I could just barely get my arm in the hole to try and guide the rod into place!!
Here's the guide rod already installed going thru the guide bushings in the glass holder,, liberally applied with lithium grease!!
Also got the gears off the window motor!!
And this is what I was calling the Trac.. all greased up as well!!
So here's my Cherry Bomb now!!!! New door latch, new door bushings, and a new door glass!!! Along with those spiffy Cragar wheels as well! She's come a loooonng way baby!!!!
