What/where is this vent from? I was going to go basic and just cut a hole with a small flap in front of it, but this thing looks perfect.Finished molding the vent into the stock hood and added aerocatch latches. It will look a lot better once the hood has some color on it.
Sent from my XT1254 using Tapatalk
how did you make the ends?
Had this a few posts ago.
First rough cuts of the wood
Quick swipe through the bandsaw
After a whole lot of sanding and shaping I have the forms for my endtanks.
So once I had the wood form, i used it to hammer the sheet aluminum. I divided the tank into 4 sides and then welded them together. The hammering and welding was very time consuming, but I learned a new craft along the way so I found it useful.
That would be a pretty awesome swap! I heard that the manual 4wd would bolt up with the right bellhousing.
