SN95 LED Gauge Cluster
Mungoo
Designing a simple circuit that lights up a typical LED is not very hard. To light it up you need to pass about 20 mA of DC current through the LED. from either a battery or some other DC source that is higher than the LED's voltage is needed. For instance, if the LED voltage is rated at 2.1V then a 5 V supply would do nicely. A resistor is connected in series with the LED to limit the current to about 20 mA. The value of this resistor can be calculated by subtracting the LED voltage from theand then dividing this result by 0.020. The closest to the result can then be used. Make sure the polarity of the LED is correct and when you connect it all the LED should shine brightly. If you want it dimmer then use a higher resistance for the resistor because that will reduce the current through the LED.
Cpotts13
Biloxi, MS
I know this is probably beating a dead horse, but what size bulbs are required for the cluster on a 2000 gt? What color is the film? and what would the differnt bulb colors combined with the film, would produce what colors? Thanks in advance..
det_riot
Dearborn
194/168 t10 leds. I believe a new edge gt has green film so if you want something different you have to take apart the cluster and sand the film off like what ferocious did
Sent from my DROID RAZR using Tapatalk 2
Cpotts13
Biloxi, MS
Im getting conflcting answers! Ive heard #74 size bulbs is what i need, ive also heard its the 194/168, idk wich!!I know the sn95 used the latter bulbs.. Anyone that has actually done the swap??
det_riot
Dearborn
Take out your cluster, measure the base of your bulb. Look up what the bulbs are dimensioned online
g36 monkey
Orlando, Fl
I posted what you need in here. I can't find the post. It should only be a few pages in though. Posted everything the New Edges need.
Bill94vert
Vancouver BC
where else can I buy the leds bulbs online... the Op link won't allow me to buy em. And yes I did a google search
det_riot
Dearborn
leds?
Me007gold
Glad to see this is so easy. I love the twist in blubs, my current ride everything had to be soldered, it was a PIA. This will be the 1st mod when I pick up my car.
Bub
Pistakee Highlands
just did mine, i've noticed that 0-55 seems to be a lil brighter almost a cyan and the rest is a blue, don't know if it's my bulbs or if this is how it is supposed to look can't really tell by the pics though. nice write up very helpful
det_riot
Dearborn
That's because there is a bulb RIGHT there. so you're getting full power from the bulb.
Bub
Pistakee Highlands
if you ran SMD's you wouldn't notice such a bright spot in the select areas. ;)
Looking good none the less.
they are smds, they are 270 degree viewing, i believe four on each side i picked em up at a swap meet for like $3 a bulb
shagg9
