The boss
MustangChris
Aurora, CO
well at least the small progress you have made is quality work! looks like it needed some love, thats for sure. :) its lookin' great.
B
BOS-94-003
Working on rear breaks and intake now.
Coated the intake black originally and although it looked better i wanted to try and smmoth it out.
Still needs some more work but hoping to coat it on my next rotation off
B
BOS-94-003
I thought the boss shanadoh made 800 HP and was a 10l stroker?????
There's different variations and levels. I know some of the newer ones make that kinda power but not sure about the 10l part.
As far as the cat, he's just a Bengal cat. His sister was on the other side of the garage and they come out every now and then to check things out. The motor is in the front attached garage, car and all the big tools are in the back detached garage.
B
BOS-94-003
Bump for a old thread. Just seeing what I need to do to post pics
B
BOS-94-003
Working from the trunk forward I cleaned up the underside, straightened the pinch weld as best as I could, patched up a rust spot under the gas pedal area and welded in subframe connectors
B
BOS-94-003
Before and afters
Akurma
Pennsylvania
Before and afters
Just read the entire thread, WOW! I definitely want to pick your brain as to what you used to undercoat the bottom side of the car and how its been holding up seeing as this thread is over 10 years old! My 99GT has rust in the same areas that yours did and even worse, the rear frame rail as well. I am going to have it all repaired but want to undercoat the entire underside side of the car to prevent it from rusting again
I used lizard skin on the bottom of mine years ago and its been holding up nice.
B
BOS-94-003
Still looks like the day I did it because it's still in pieces in the same spot inside the garage. You'll like my frame rail repair coming up next. I just did por15 on the rusted areas and then coated it with automotive paint. Can't say if it'll hold up or not because it hasn't been tested
B
BOS-94-003
They call it the rust belt for a reason. Drivers side strut tower and frame rail. Was hoping for a easy splice but because the frame was rusted inside the outer sleeve I had no clearance for welding. Took the back half completely out so there would only be one splice. K member bolts still had a couple miles left in them but decided to replace them while I had it apart
