Unique build.
Wichers123
Wichers123
Covington, louisiana
So no progress on the heads buuuuut I did score something awesome that I will be going to pick up today that ill reveal when I get back home...
Oh I did finally get some pi cams and finally scored a cobra intake boot.
ster302
Madison, wi
Those valve covers and intake turned out nice. Valve covers should stand out pretty good when its all back together.
Phatboy
Sweet surprise. What paint did you use on the valve covers and intake?
vermilion
maryland
i see where ford went with a dual blade setup. maybe to promote a vortex effect. however i think if you opened on the intake manifold throttle inlet and single blade throttle body would introduce a lot more air. for a boosted applications it creates a bottleneck. for instance look at cars with PD blowers IE: whipple and KB. the mouth is effing huge and creates less inlet restriction.
Wichers123
Wichers123
If I was only worried about big power then I would change out the throttle body but I'm just going simple...
i will add i like what you done so far.
Thanks
Wichers123
Wichers123
Well I decided to just go for it this weekend so I installed the pi cams into the car. Deff need a tune now the car pulls better now but down low has some pinging could be the tank of 87 but its a good excuse for a tune.
