[MENTION=15705]mcglsr2[/MENTION] only question is, what are you doing with a video of dalamar brushing his teeth?!?!? Lmao
If my UPR k member ever fails, Ill be sure to post it up. Ive looked it over pretty thoroughly, and all in all, it seems to be pretty well built. The welds definitely dont look like they were TIG, but they look to be plenty sufficient. Im not saying all parts from them will come this. Even welders have wild drunken nights and hangovers in the morning. At that piont, its quality controls job to make the welder grind that crap weld off and lay down a quality weld. Now would I buy another UPR product??? Heck no. Their customer service was very lacking after I placed my order. As for the k member, it came installed on the car already.
I noticed the engine in my car was sitting at an odd angle. After poking around, I noticed the one off the alignment tabs on the motor mount wasnt sitting in the hole on the pads. I dug up some info, and found out that the hole on the pads arent for the tabs on the actual motor mounts, but they are for aligning the parts in their jig when they are made. Solution, cut the tab off or get motor mounts that dont have the tabs. After the awe inspiring confidence that the installer of the motor instilled in me, I decided to check the squareness of the k member to the rear control arms using a plum bob. And of course it was off also. Even with top of the line parts, if whoever installs them doesnt do it properally, the outcome will become subpar at the best.
I know 100% for sure I did not cut my piece off and they fit correctly in the slot. I also did not have to adjust my kmember after install asi left everything loose till I had every bolt in, then tighten it up diagonally.Almost every company I've looked at who makes k-members states that you are suppose to remove the tab on factory style motor mounts. I've noticed this recently while looking around at k-members
And just because you can work some hand tools and install parts doesn't mean you should. Lol how about this you save money on doing the job yourself then paying someone "knowledgable" to do the job, I save money on buying cheaper parts and understanding that I might have to adjust or install "correctly".Don't get me wrong, I'm all for a funny pic once in a while but you've posted 10 in the past 2 pages.
mcglsr2 only question is, what are you doing with a video of dalamar brushing his teeth?!?!? Lmao
I like working on my own stuff and I do a good job doing it, if it's something outside of what I can handle I bring it somewhere else or I get help, but so far that hasn't happened more than once.
Paying someone else to work on your shit and expecting them to do a good job is a one-way ticket to disappointment.
