Wichers123
So what's the idea of changing k members?Mustard that might make sense if the point of a K member was to be light weight but it's not, that's just a secondary benefit.
3 things ive learned here.... someone has to much time to play with GIFs, someone here hates UPR and last i learned that if i was black and died due to a UPR part failing there probably would be a riot.... but if i was white and a MM part failed no one would believe it. am i wrong?
Btw Evil. Love your car... Im doing an LS swap and keep debating on what color to go with and with what wheels... but your car makes it hard to say no to black and fr500's (i think thats what wheels you got?)
Yep, satin black with black chrome fr500's.
Thanks, it's a work in progress!!!
The only reasons I installed a k-member was to save weight and have more room to work on stuff.
The original k member is the strongest out there and more ridged.
ok... I'll call BS.
[video=youtube;a1Y73sPHKxw]https://www.youtube.com/watch?v=a1Y73sPHKxw[/video]It's actually true.
It's actually true.
No, other than everyone at the racetrack whose opinion I trust has agreed. But you're right, take that and two quarters and it's still only worth 50 cents. The stock k-member was designed by Ford to last forever, and is made of thick, very heavy steel. It's built like a tank. In my humble opinion, the only one that may come even close to matching the strength and rigidity of the factory k-member is Maximum Motorsports. Most normal manufacturers wouldn't come close.
Paul.
Just cause Ford makes something, i wouldnt put too much faith in it. Engineers are usually at the mercy of the bean counters. I just replaced some lower control arms on a 2000 Lincoln Navigator, and Im surprised how flimsy though were for such a heavy vehicle. They had rust holes large enough through them in 2 places on each lower control arm that would allow more fingers in it than a working girl.
Paul.
