1995 mustang build up :D
RedTwilight
Roxboro, NC
Well it is possible to paint stuff to look like Carbon Fiber.
This didn't turn out too bad. If I would have done the third step, it would've looked even better.
it is possible to paint a CF finish and doesn't even require special parts short of those non skid drawer liners and some paint. But it is MUCH harder to do on all the curved surfaces and with all those I am not sure how you would go about it. Either way honestly once you get use to the real stuff the faux carbon fiber finishes are good from far and far from good.
evilcw311
Most Evil Member!
Louisville, KY
Painting it would be a nightmare to make it look right with the curves. This is why I said hydro dip as it works a lot better and yields great results.
But all of this is for nothing if he doesn’t want carbon fiber looking valve covers!!! :)
I got as far as he did polishing the top of the valve covers. The nice flat top is easy and it isn't till you get into the curves/grooves on the side that it starts to really take some time. This was also while I was in the middle of polishing my cobra intake. 2 years into polishing the intake because it was my first large scale polishing project and I didn't really have the proper power tools so it was taking for ever basically by hand. It was about this time I realized that if I polished the valve covers that I would have to polish or in some way do something to the bottom of the intake or is just going to be a mirror reflecting the nasty bottom, or half done bottom or what ever it ended up being but I really didn't want to touch it.... It was then I decided to go with powder. good news is that nice flat top(after blasting) is perfect for powder/paint.
1994stangfan
1994stangfan
Ontario canada
First rocker can’t bet is blasted. Now I am debating whether to bloating the sides black, aluminum colour, or polish.
1994stangfan
1994stangfan
Ontario canada
Opened the ports up a little more.
Also rented a power steering pulley puller and removed the pulley, pump and bracket. Will be painting or powder coating the brackets this week.
1994stangfan
1994stangfan
Ontario canada
Started modifying the power steering bracket, with the Kenne Bell I no longer need the stock idler pulley so I decided to remove that section of the bracket for a cleaner look.
1994stangfan
1994stangfan
Ontario canada
The bolts arrived today. I am very impressed with how well organized everything is, separated by part and labelled clearly.
Also dropped the pulleys off at the powder coater.
This is the before pic u will post an after once I get them back
1994stangfan
1994stangfan
Ontario canada
Installed the heads, new timing Chain new lifters, pushrods, rocker arms.
Painted and baked the lower intake.
any reason your using the fox body AIT?
I also thought you didn't want the paint out-gassing in your personal oven?
IDTag
