1995 Saleen clone rebuild
totalchaos
totalchaos
Anyone have a fox body throttle and cruise control cables , and the bracket for them.
totalchaos
totalchaos
so went on a 10hr road trip (round trip) to sell the old intake and pick up parts from the mustang shop in Calgary. Picked the lower intake to go with trick flow r upper , sct chip , ford racing wires (red) , injector adaptors to run 03 cobra injectors , slot style maf , adaptor harness and weld in flange for maf , and scoripion roller rockers.
totalchaos
totalchaos
Didn't take any pics of putting the short block together , but here are the pics I have
had grind the valve cover to clear the rockers
painted the lower intake to match the upper and played around with painting the upper
totalchaos
totalchaos
motor specs :
95 351w roller block - 30 over
scat 9000 cast crank 3.85 stroke
scat I beam rods 6.2'' long 7/16 arp bolts
icon forged flat tops 4.5cc
meling hv oil pump
comp cams xe 282hr cam
trick flow 11r 190 heads 66cc
scoripion 1.6 roller rockers
trick flow r intake
39# 03 cobra injectors
factory fuel rails
75mm fox tb
slot style maf
has about 11.01 compression
DavidBoren
Pacific Northwest.
That engine is nice. Really nice. I, personally, would have kept the tubular intake, but that's just me. Good job, man. When is the engine going back in the car?
totalchaos
totalchaos
thanks nothing a little bit of time with a parts washer and some paint....lol. Used high heat brake paint on the block , acc. brackets , and intake in hopes it last a bit longer than normal engine paint. I think the tubular intake would starve the motor for air....but now I need to figure out how to make the trick flow fit which is about an inch taller..:BangHead:. Hoping to have it installed by mid april , need pushrods, fab up the maf pipe / cai , and more importantly a power steering pulley.
totalchaos
totalchaos
Ordered a ps pulley from asp , and a luk pro-gold clutch.
totalchaos
totalchaos
So I looked up the part number on the flywheel and found out , the guy that built the car before used the 302 flywheel on the 351:deeplist:. So I ordered up the right flywheel and decided to change the balancer just to be safe.
totalchaos
totalchaos
Had to order a cobra r hood , got the motor dropped in the car.
totalchaos
totalchaos
Changed out the valve covers for a set of trick flow tall ones. Found a s281 spoiler semi-local so picking that up on Saturday.
totalchaos
totalchaos
So my brother sold the car to my son for screaming deal. The car has now received a 100 shot of nitrous. Need to swap in set 3.73 gears in the rear. Thinking about swapping in a megasquirt system in.
evilcw311
Most Evil Member!
Louisville, KY
Holy hell!!! You’ve been gone a while!!!!
peasant99
