Thanks man! Love your build, I follow it on here and Instagram!awesome!
Anytime brotha!!Thank you my dude and thanks for the support!
Front shocks are new, rear are konis which are good. Motor needs head gaskets so rebuilding it along with new belt and fluids. Radiator is new, hoses will be replaced, I have new coil packs and wires going in as well as plugs. it will need some tires, I’m trying to find some 305s for it. I have the truck throttle body for it, I’ll pick up a crown Vic plenum. Waiting on heads from black. And I do plan on cleaning gas tank and the injectors. New fuel filter will be put on. As well as rotors and brakes on all four corners. Car is an auto, does need front pump seal. And I do want to slap some 373s out backI’d inspect everything; brakes, suspension bushings, fluids, belts, hoses, plugs, clutch, fuel filter, fuel pump strainer, internally inspect the tank, check the tires, etc
If all of that checks out, swapping the rear gears is a great bang for the buck upgrade.
No rush man!Dang.....i need to get busy! I dont need you waiting on me!
Yeah I’ll be reusing my timing cover and oil pan. I will need to find a 8 bolt flywheel for itSince you have the timing cover you likely have everything you’ll need.
Which one?You could go ahead and build for higher compression!
I'm going to look around inside my buildingsYou could go ahead and build for higher compression!
