Huhokay, so on to TT, classes and points. After I get done with HPDE, I will move to TT and give that a shot for awhile. After that, I'll probably be looking at W2W. Right now, though, I want to focus on TT and see what I can do against similarly prepared cars.
A quick background on NASA TT and points in case you are unfamiliar: There are 5 "normal" classes and then 4 "super" classes ("normal" and "super" are my words, not how NASA describes it). The classes are, from slower to faster: TTF, TTE, TTD, TTC and TTB, TT3, TT2, TT1 and TTU. For reference, my Mustang (95 V8 with less than 226 hp) has a base class of TTE, my 11 STI has a base class of TTB.
The base class is where your car starts assuming you have made no modifications. So if I had a bone stock 95 GT, I would race in the TTE. This keeps like cars in the same category and emphasizes driver skill more, not driver money.
As you make modifications and improve the performance, you get points for certain things. Every 20 points you accrue, your car moves up a class. So if I have 25 points in mods to my Mustang, I am no longer in TTE, I am now in TTD.
So the goal is to either pick a class and mod for it, or if you have existing mods then add up the points you have and see where you end up. Then either max out points for that class or remove things to drop down a class.
As I said, my Mustang starts off in TTE. If I keep the car as is now, here's the points I currently have:
- The Mustang in TTE gets an automatic 7 points
- Non R-compound DOT tires, 2 points
- 255mm width tires, 4 points
- Modified airbox, 1 point
- Modified exhaust piping, 2 points
- Removal of cats, 1 point
- Changed LSD, 1 point
- Modified shocks/struts/dampers, 3 points
- Modified coil springs, 2 points
- Modified control arms, 4 points
- Add panhard bar, 4 points
- Modified brake calipers/rotor diameter, 2 points
- Add front lower brace, 1 point
- Add SFCs, 3 points
Total:
37 points, so ONE class move up, which puts the Mustang in TTD, with 2 points to spare (it's 0 based, so one class ends on a 9, the next class starts on the next '0').
There's a little more to to, but the adjusted power to weight ratio for TTD is 14.25:1. This means that the power/weight ratio cannot be any better than 14.25:1 for TTD. The Mustang is currently 18.59:1...ouch. What that basically means is that my points are from chassis, brake and suspension mods, not engine mods. If I decide to stay in this class, I'll be interested in seeing if the under-powered Mustang could hang with the other cars - or rather if I can hang with the other cars.
