Weight Reduction: - 8.5 lbs
When I pulled out the stock CD player, I forgot about the amp underneath it. I took it all apart again and pulled the amp which wasn't being used and 2 supporting brackets = 3 lbs. I also had some annoying rattling coming from underneath the steering column. I took a peak and noted 2 plates that were loose and rattling against each other. They got pulled which solved my rattling = 3lbs. Lastly, I removed the black plastic blocks on the rear bumper which were filled with dirt. Surprisingly, they were 2.5 lbs with the weight of the dirt and only 1 lb cleaned out.
I guess when you put it all together; it adds up in the end! With the last 3 weight reductions, I have cut a total of 74.5 lbs for free! Next step is to weigh the car so I know where I stand.
