build up questions
5.0boi
im looking to build a 347 stroker with a trick flow twisted wedge top end kit. here are my questions will my stock block hold this power? wat are the hp capabilities on factory 302 blocks? if i dont go trick flow top end wat top end kit will be good with the stroker kit? or any other info u have that would be good for me please let me know thanks guys......
ram360
you looking to add some sort of power adder or just an N/A stroker?
5.0boi
i was thinking high compression n/a or regular compression nitrous once i find more info i will know
5.0kid
stock blocks crack anywhere from 450-550 rwhp from what i've read in the past. More easily with nitrous...
LAFENATU
- Holley Systemax II intake
- AFR 185 Cylinder Heads
- Ed Curtis cam
That will make more power than a TFS kit.
5.0 Kid..
Nitrous is no worse/better than boost etc. When comming to breaking a block.
2slo95fiveoh
Lawrence, Kansas
X2. A rough guess about a stock blocks "breaking point" is about 500rwhp. The TrickFlow Top end kit is a very good kit (I would know),
however, the cam and heads are just a touch on the small side for a 331/347 stroker. If you are a little budget limited, a stock block
stroker with a set of used AFR 185cc heads, Custom grind cam, and Edelbrock performer/trickflow/holley systemax intake would be a pretty
decent combo.
5.0kid
- Ed Curtis cam
5.0 Kid..
yah, sorry i was typing that quickly. any extra pressure from power-adder sources should be considered.
5.0boi
how much hp u think i should be puttin wit the kb or scat 347 stroker wit the afr 185s and the trick flow manifold?
scott5
myrtle beach, sc
the question is how much power you want? What you going to use it for, track or street? Name what your goals are and dont stray from them and you will be happy with your end product. I wouldnt put the TFS top end kit on anything bigger than a 306..
5.0boi
imma do a street strip car not my daily but weekend fun car mostly track....im goin 347 i have decided not to use to tfs heads im lookinf to get afr 185s
LAFENATU
10.5:1 or so compression...don't be afraid of compression. I would do a solid cam instead of a roller.
Should be somewhere in the neighborhood of 400. Need a better intake then the TFS though. Systemax or Victor 5.0 etc.
Paul
Why on earth would you want solid flat tappet over hydraulic roller? Hydraulic roller is superior in pretty much every way.
Solid Flat Tappet < Hydraulic Flat Tappet < Hydraulic Roller < Solid Roller
Paul.
5.0boi
10.5 compression sounds good but is it good for all motor or should i go higher all motor
Paul
10.5:1 is plenty. Depending on the climate and available gasoline (91 vs 93) it can lead to detonation.
5.0boi
how many cc should the heads be? i heard there were some parts to help the block from cracking
scott5
myrtle beach, sc
185cc AFR heads
I have had alot of luck with anderson cams, but can never go wrong with a custom
Is the setup i would go if i was just doing an NA car and nothing less than 10.5:1 compression
LAFENATU
Paul,
I meant to say a solid roller instead of a hydraulic roller.
My bad.
I would not hesitate to do 10.5:1 even in Florida. You have 93 octane..no prob. Worst case scenario pull some timing.
There are plenty of new cars running 11:1.
