Coyote SN95
Status
Not open for further replies.
neverenuff
neverenuff
Thanks 9838stang! Can't wait to work out all the kinks
Sent from my SM-N900V using Tapatalk
BMAC96GT
Virginia
This build is awesome. I love it. I plan to do the coyote swap eventually. I appreciate you putting your build on here. What transmission did you end up running? Sorry if I missed it. And were you able to wire your factory gauge cluster for the swap?
neverenuff
neverenuff
I appreciate it man. The trans is the stock t-45- until it goes with a Ram HD clutch. The future plans are a built t-45 with a McCloud clutch or a t-56 with a twin disc. As far as the factory cluster, all but the oil and temp guages work. I have an Autometer oil pressure and soon will have the matching coolant temperature piece. Speedo stays the same with factory transmission, the tach is wired to the crank sensor
bluex
All the pics work again, yay! this is a bad @ss car man. Nice work I bet it's a blast to drive.
neverenuff
neverenuff
Haha there is a lot of money out here, I've seen Hellcats and ZR1's, not trying to mess with that crowd....until TVS or twins!
neverenuff
neverenuff
Thanks StreetPilot! Good looking stang you got there, wish mine was black.....until it gets dirty lol
neverenuff
neverenuff
Finally ordered a tuner and what a difference it is from an X3! Now I need to book a dyno tune and get all the kinks worked out.
96laseredcobra
Farmington MO
I love my x4 need to get myself a tune for the gt. Right now it's the 96 Towncar
Sent from my SAMSUNG-SM-G890A using Tapatalk
neverenuff
neverenuff
Yeah, I should've gotten it a while back, the X3 is similar to an old gameboy haha. This one is more useful with the factory engine sensors/gauge readings
neverenuff
neverenuff
As for a tune I'm probably going to Racers Edge, they seem to have the Ford modular tunes on point
neverenuff
neverenuff
Finally got the bracket and P/S tank back from powdercoating
neverenuff
neverenuff
Not as much progress as I'd like but it is installed, only to find out I need to fab a hose with a tee on the supply side if the reservoir.
neverenuff
neverenuff
Basically the factory reservoir is hanging out, not mounted to anything. They do not make a bracket that works at least not yet as most swaps go manual brakes and manual steering.
neverenuff
neverenuff
Finished building the hose and picked up some GT350 coil covers
Status
Carolinastang78
