egr tube with intake spacer?
RJDCobra
Plano, Texas
is there any extension adapter for the egr tube? i have to use a 3/8 intake spacer to my upper intake can clear my trickflow valvecovers. with the upper intake/egr valve raised i cut the egr tube and clamped a rubber heater hose in the gap, but it pops a hole in it about every 3-4 months of driving. im looking for a more permanant fix. didnt edelbrock or russell or who ever have a adapter that bolts to the header primary bung. or anyone know of a homemade trick?
95-stang
I just found some tube the same o\d and welded it in to extend it.
FULLSCALE
Will that adapter only add 3/8" to the tube or could I use it with my 1" spacer? I guess I could just put two together but that would probably look like crap. Does anyone make an adapter for a 1" spacer?
Paul
You'll need more than one. Or just don't run an intake spacer.
blackpony
you could maybe use one on top and one on bottom... should blend in and be ok....
