Snorky
- Joined
- Feb 10, 2022
- Messages
- 1,469
- Reaction score
- 1,356
Made some big moves here. My shipment of the above components came in.
So I transferred the v10 from the engine stand to the cherry picker very carefully. I will say. It's nerve racking picking it up with these alternator bolts lol. The 4.6 i do with confidence.. the 6.8 is significantly larger.
once transferred to the dollies and slightly suspended. Used arp fasteners and lube to attach the mcleod steel flywheel. Hammered in the dowel pins. Then used arp fasteners to attach the mcleod super street pro clutch(my first larger single disc...) if it runs and it sucks to push in it will get an RST clutch. Perhaps I'll use that as an opportunity to run. The rst from green car in this and then get an RXT for green car... hmmm
Behold in all of its glory!!!
Next I hammered out an old alignment dowel from the 3650 I acquired who knows how long ago for this. Used some 220 grit sand paper to clean the holes up a little and take down high spots from the punch. Added a new pivot ball. Greased the pivot ball. Throwout bearing face. Splines and retainer sleeve with the appropriate lubricants. High temp grease on the bearing/splines/retainer shaft. Moly lithium high pressure on pivot ball. In the new clutch fork and bearing went.
Then married the tranny lol, cant say that everyday.... And voila!!!
Tossed on the starter and the. Just for funsies dropped the intake ontop. (Still need to final assemble that part and figure out the coolant pipe in the valley.
so motivating!!!
