Here are my fans which are grounded when on. If your low fan turns on when power on then you need to make power on Value on and
active Value off since CCRM is in failsafe mode which trips low fan to be constantly on.
High fan
Autotune for warm up.
If you look above there is a Data Logging feature which you can save your session. Once saved you can open Megalog viewer and see anything and everything. You can also use VE ananlyze which will look at all you data and make recommendations on corrections to you table. You can then save and uploaded to TS.
High fan
