Not so productive build
J
Jp6.0
So guys that have tfs valve covers. I am trying to figure out a way to put a better oil filler neck/vented oil cap on these valve covers. I have already got the vented an breather fitting and I figured I would run that on each side with the pcv oil filler cap. My issue is all the ones I am finding are either for stock valve cover or they are threaded. I need one that pushes in the grommet or I guess threads on the valve cover like the vented breather fittings. If anyone out there knows where to find one of these I would appreciate a point in the right direction.
RAU03MACH
NEW MEXICO
As far as I can see
On the tf valve covers there is not much to them cap is what it is i
This is a sample of what I did for ventilation
If you do see somthing different let me know20210227_173431.jpg 20210227_173339.jpg 20210227_173259.jpg 20210227_173157.jpg
J
Jp6.0
2932E7E4-B181-4577-8A01-EC65AB6E7A73.jpeg 782FE44F-FBB2-490F-AEDB-8138011B121F.jpeg 782FE44F-FBB2-490F-AEDB-8138011B121F.jpeg
Got my baseline control arms put on the other night. Wasn’t a bad job at all other than 2 stuck bolts in the old control arms I had to put some heat on.
Not going to blow these out of the water with hype, but damn did they make the car tight in the ass end. These are definitely worth the money in my opinion. Got to get some gas for the welder then I’ll get the frame connectors and tq boxes welded up.
J
Jp6.0
So, for all you out there that have done the team z k member and a arms is there anything I will need to get that might set me back a day or two if I don’t have it? I have been watching YouTube and reading a lot and here is my plan.
I am going to replace the steering shaft, steering rack, rack bushings, motor mounts, get what I need to make sure the k member is squared, and obviously any fluids or cleaners I might need. I just figured I would ask y’all if there is something I’m not thinking about that might stall me that you ran into when you installed yours?
thanks for any help it is very much appreciated!
50HSN95
Minnesota
I'll second that, Baseline makes some very nice parts, or I should say Kevin does. I think he lakes that stuff himself, but regardless very nice product, and great product support.
