People who have an auto with a stall..... come in
voidfinger
if your sticking with npi heads then 3200 is about right. stock pi head car's like 3500
B
Brian95SVT
Chesapeake, VA
I'm keepin my NPI heads and thinking about a PI cam, I already have the PI intake. Later down the road I wanna P&P the NPI heads.
Jrgunn5150
Until you get later down the road, a 3k stall should be just under the meat of your torque curve. In other words, a good match. A 3600 stasll would be even closer, and give you the room to grow later. Like I said, lol, 3k is what I suggest to nearly everyone, justy to get them used to the idea, but if you don't fear the stall, 3600.
voidfinger
IDK, with the ported npi's i wouldn't got over 3500... thats just me though.
Jrgunn5150
3600 (3500 whatever, it's a 100 rpm), is just starting to touch on the meat of the torque curve. That's right where you would want it to stall
voidfinger
wow mine with the npi heads got into the curve at like 3100 hundred... I just looked at my dyno sheet lol.
Jrgunn5150
And it picks up until about 4k, then carries until 5500, gota love that stock H/C/I combo they designed for motorhomes are some crap, lol
voidfinger
... it started going down around 3700... but thats also the rpm that the A/F ratio went to 11.8:1 .... gotta love these stock tunes on these cars.
B
Brian95SVT
Chesapeake, VA
Originally a friend told me to get a 3500 stall, shift kit *which I chose JMod* and 3.73 gears and it would wake my car up.\
So maybe I will just go with the 3500 stall and call it a day.
Really you said there wasn't much of a difference, right?
Jrgunn5150
3600 3500, what one person calls one, another will call the other, potato, potato kinda thing. It's not exact, adding cams can change your stall speed by 100 rpm, alot of things can and will.
FASTANG
as with any stall and shift kit mod, install the biggest trans cooler you can physically fit. I went with
a stacked B&M 24,000 GVW for about $65. I have heard of the trans pan boiling over from the heat
that is generated from these mods. Also, it will add longevity to your trans.
Jrgunn5150
my96gtstang said:
So wouldn't it be better to start with a smaller gear so if can grow? or do i have that assbackwards hah
You lost me there.
B
Brian95SVT
Chesapeake, VA
ok, thanks.
I know J.R. said to get one as well.
off topic but, I need a new oil pan because a while back I hit a small steel box looking thing on the interstate *had no choice, 18wheeler beside me and another behind me.... bad day* and also that bar that sits right under the tranny which I think is a Panbar? *that will come with my suspension package, so no worries* but yeah, a nice sized undented oil pan.
anyways, where could I find that B&M 24,000 GVW? Will that fit in with most of my stuff being stock? Also I wanted to get a new radiator. Also a nicer coolant tank and all. I've seen pics of them and saw one in person and it looked soooo clean. It was black with a screw on top... Canton or something makes them..
Jrgunn5150
Look on Summitracing.com They have about every size and type of trans cooler you can imagine, find the one you like and then google it for the best price :thumb:
They also carry the radiators.
Jrgunn5150
If you just want to put it in front of the radiator, pretty big, probably 12"x12 pretty easily.
As a note, some people prefer not to mount them in front of the radiator so as to not block airflow to the radiator. I personally wouldn't sweat it unless you live in like Arizona or something. Just an FYI
B
Brian95SVT
Chesapeake, VA
Where else would you mount it if not infront of it?
I've also seen ones that were infront leak onto the radiator...
FASTANG
Yes, Summit is where I got mine about 8 yrs ago. I have seen them in their current catalogs, also.
I also mounted it in front of the rad, and have zero issues.
Jrgunn5150
If you get one with a fan you can mount it anywhere you feel like running the wiring and lines to pretty much. And the street rod compact ones can mount on the framerail.
They shouldn't leak though, but yeah, if they do leak, it will go all over the radiator.
Suprasuavy
