Project Deceptive GT: The Coyote Swap Reboot
Deceptive GT
Nashville, TN
This needs an update since the direction has changed.
Since all my pictures were lost on Photobucket and I have gone back and forth quite a bit over the last few years with the car, sold and bought another Cobra to make the crazy build, I figured I would just start from scratch.
Here is my 02 GT the day I bought it, 22.5k miles on it and stock except for a catback and neons.
Here is after my first round of mods. Eibach Pro System Plus, 18" Bullitt Wheels, MAC CAI, Simco Gauges, stereo ugrade, Pro 5.0 shifter
This is after a few more changes, Steeda 18' Ultralites, tint, Mach 1 Lip and Grille Delete and for the most part, where the car unded up (minus spoiler delete) before the rebuild began.
Some may remember that I was doing a Saleen Clone, I sold all the Saleen stuff as I changed my mind. I wish I never went down that road. With the exception of hood, Mach 1 Lip, and Grille Delete the car will be stock body.
Engine:
Gen 1 F150 Coyote
Catted X for emissions
Prochamber
Borla XR1 Catback
Drivetrain:
6R80
Suspension & Brakes:
Koni Yellow Shocks & Struts
Maximum Motorsports Coilovers
Cobra F&R Brake Setup
Interior:
Corbeau GTS II seats
Morel Tempo Ultra Components
Diamond Audio D310 subs
Diamond Audio D600.4 & 1000.1 amps
Simco Gauges
Bullitt Pedals
Exterior:
Haartz Stayfast Canvas Top
Spoiler Delete
Mach 1 Lip & Grille Delete
Raxiom Smoked Taillights w/Sequential Signals
Cervini’s 00 R Hood
Deceptive GT
Deceptive GT
Nashville, TN
So, some progress I have made over the time I have had to do some work is the removal of the stock sound deadening material and replacement of new stuff. I used Boom Mat and Noico Liner. When I removed the old stuff I wire wheeled the metal, primered, and repainted the metal to make a good surface.
I mounted the crossovers for the Morels after I had put Noico Liner on the doors. I also ran all new wiring through the car for the stereo and ditched the factory stereo wiring throughout.
Deceptive GT
Deceptive GT
Nashville, TN
Things have changed other the build. Selling the Eaton swap parts.
Gibtecs will go in the Cobra.
white95
Apex Junky
Prairieville, LA
I'm very interested to see where you end up with that engine combination. I'm building something similar, but with stock cams.
RedTwilight
Roxboro, NC
+1
Plans for mine won't be too far off. I still haven't figured out what compression ratio I want to shoot for yet. But with the heads I have; it might be a little bit wilder combo.
Deceptive GT
Deceptive GT
Nashville, TN
+1
I imagine with all the mods it should be around 600hp and 550lb/ft to the tires. All that I have read about the TVS 2.3s has been great. Guys on untouched longblocks make 600 &550 all day at 20lbs. Sure, I will not be running as much boost but the bump in compression , cams, headwork, and exhaust should makethe car very efficient and lay down some impressive numbers.
white95
Apex Junky
Prairieville, LA
I'm assuming since I'll be running the standard M112 [2.76 pulley/14#] with largely stock heads, I'll be well under 600 whp. Your pistons are going to put you in the 9.8:1 [or so] compression range? The set we've spec'd for my combo will put me around 10.3:1, perhaps more though because I had the heads decked.
I've also considered a M122 swap for a relatively cheap bump in power capability. We put one on my wife's 3V car and it pulls pretty good @ 11-12 psi.
Deceptive GT
Deceptive GT
Nashville, TN
I was told that the CR should be 9.731:1 not taking in that the block and heads will be decked so maybe 9.75:1 or so. I plan on running a 3.2" pulley which is supposed to be 15lbs but will probably be 13 or so for me with the other work and ability for the engine to move air.
Deceptive GT
Deceptive GT
Nashville, TN
I will let this sit and stew while I wait for a delivery.
evilcw311
Most Evil Member!
Louisville, KY
Is that a belt driven air compressor?? So now you can air up your tires while driving like Hummers?!?!
Deceptive GT
Deceptive GT
Nashville, TN
I have not posted in a while. Started a new position with an amazing company that has me traveling.
Build has changed to keep the 2V setup. Lots of pictures will be posted as I will be making my machine shop trip in three weeks. Just waiting to make the trip for the heads, pistons, and Tork Tech Kit.
Here are the Valvesprings and Cams I had spec’d.
Deceptive GT
Deceptive GT
Nashville, TN
Ordered the Timing Components, Head Change Kit, new water pump, and a few extras too that I researched as helping with the timing component differences in using the Teksid Block in a 2V setup.
Deceptive GT
Deceptive GT
Nashville, TN
You guys need to hit up Jeffery Shockey at Apocalypse Performance for your modular needs. Came home today to these.
Diamond Mod2K Pistons and TrickFlow 44cc Heads.
Deceptive GT
Deceptive GT
Nashville, TN
Got the hood latch adjusted to get the Cervini Hood to close and latch properly. Also got the Cobra throttle and cruise cables hooked up.
Suprasuavy
