Single turbo 1998 gt
Lanter
Indiana
If you have specific questions on the 98 fuel system I can answer most. The 98 is a bastard year, being a return fuel system like previous years but with a similar tank to the 99+ cars. The pump is housed in a basket as opposed to being inside tank baffles like the 97 and older cars. The drawback is standard pumps for the 97 won't fit and if the pump flows a lot you can suck the basket dry unless you cut holes in it to allow it to fill faster. The 99+ cars (including the 03-04) are returnless fuel systems which operate with a variable voltage pump to slow down how much fuel the engine gets at low loads. The best option for drop in pumps on a 98 are the svt focus or lincoln aviator, both would be a good idea to drill the basket to let fuel fill it quicker.
Stock982v
Houston , Tx
So the svt focus would be a direct drop in?
Stock982v
Houston , Tx
[/URL][/IMG]
Lanter
Indiana
From what I have read it is, now I haven't ever tried using a SVT focus pump. I have a glenns gp1000 fuel system with a sumped tank. I know without a doubt the aviator pump is a drop in and if I didn't need so much fuel that would have been the route I would have taken.
Stock982v
Houston , Tx
Maybe ill get a aviator pump , ive never heard about using one until now...
1bad95
Focus pump will drop in. My tuner advised me that with 98 being a return system that he didn't expect the pump to support more than 375hp or so. I ended up selling mine and bought a walbro 290lph setup. Whole setup, new bucket and all. Just drop in and plug in
Sent from my XT1585 using Tapatalk
1bad95
Also if you buy a new drop in setup be sure to know wether your car is a California emissions car or not. I bought a non Cali setup first before finding out mine was a California emissions car, but my car was originally sold in Cali
Stock982v
Houston , Tx
How do i find out? searching the vin number?
1bad95
Easiest way is unplug your plug to your fuel pump. If 4 wires if non Cali, if 7 wires I think it was it's Cali.
98snakehorse
Southeast, IA
Im at roughly 400rwhp right now and have a 255lph pump and did not drill holes in the bucket. So far no issues. Next tune this spring I'm expecting to see around 410-420 to the tire and am hoping this wont be an issue
Stock982v
Houston , Tx
What pump did you go with?
Stock982v
Houston , Tx
Ok guys idk how to even say this but the car has had a little turn , I purchased a nitrous express kit going to spray 150 until summer, plan is to do long tunes typhoon intake and pi heads and cams , Then the summer time I can work my A** and have it turbo , if I blow the motor won't be a big deal they are only $400 at max , sorry for the big change... Don't kill me Frank
98snakehorse
Southeast, IA
Lol nitrous is good too. Doesn't make the great noises that a turbo would though
Sent using my Typewriter
Markstang73
