Good question, I have had problems with heads cracking and counterfeit parts blowing up engines. Both blocks have had rebuilds for mistakes. I have done tear downs just to look see what good and bad because I was bored. The forged aluminum Trick Flow engine is in the car with 1000 miles on it making 374 at the crank and 20MPG with 3.73 rear gear which I am happy with and it rev's nice but that engine is made for a blower or turbo and I have done 3 of those engines already so I want to sell it and am doing the iron block now. The iron block came in the car so I want to get it back in there, it was never bored out so I am doing it now to .020 over with new pistons. I have built this engine multiple time with different combinations of parts and the vid. shown above was one of the small cam big compression builds that had bad heads. This time I am using better parts and the RWHP should be around 300 so I do not need the high level of strong parts the motor for sale does. I have a lot of dyno time now on both blocks and the close piston to head builds so I am comfortable I am not going to bend parts and that allows high CR which give good torque at idle without going to forced induction.
The problem is always air flow on the intake side, we are limited by the 90mm piston size to low torque and even the 4V heads suck down low. Ported PI heads are OK but the Trick Flow heads beat them by 15 HP with a big intake valve and more room for a higher lift cam without going crazy on piston design. The intake manifold is a problem area, the engine really likes long runner length to help jam the cylinder from flow inertia and going big like the Edelbrock kills flow speed, it is really for drag cars, port velocity is low till 5k then it is happy but drivability suffers. The stock PI manifold is good but is designed to quit at 4600RPM and we need a little more to have fun which is why the 3V set up works so well with the adjustable intake. With the butterfly gate closed the intake ports are the size of a nickel and when they open they are 2 square inches each. The closest thing I see for the 2V heads is the Trick Flow Street Burner intake with long tapered runners. TF did give internal dimensions of the runners which is why I think they could work b ut If you have read my builds you know I am not a TF fanboy.
Decisions, decisions....
Your comments and flames help.
