The SBF 306 Engine Build - Updated 09/25
Petek
Re: The SBF 306 Engine Build - Updated 03/30
what exactly is involved with anodizing? i know absolutly nothing about it.
ps. cnc machining is pretty much just changing tooling, punching in some numbers, and then standing around. in my personal experiences anyway. its pretty boring after a while.
P
Paul
http://en.wikipedia.org/wiki/Anodizing
Well, there's a little more to it than that, but yes. I guess.
I want a job where I can create things. It seems more meaningful to me.
Paul.
Petek
So in which scenerios would you anodize aluminum rather than powder it?
Paul.
Theres more to it if you are the designer, if not than its just tool changing and punching numbers.
But yah, i really enjoy my job. custom fabrication is what i live for.
lethl-lx
Nice Job Paul , I do alot of PC`ing and that Gun Metal Gray is a sweet color . The pic`s really do do it justice .. anyways Super job .. :thumb:
Kornnut
Any updates? I love this thread.
P
Paul
I've been working all days/nights/weekends, so no updates other than I got 20 pounds of new powdercoat in the mail. :)
Paul.
P
Paul
Well, I finally got a little more work done. I've been crazy busy at work, so the car has been on the back burner for a couple weeks.
I got my valve covers all sanded down smooth, and coated them gunmetal gray to match the aluminum accessory brackets. I'm happy with how they turned out. It only took about three hours to sand them down nice and smooth. I think they look great for stock valve covers. :)
I also got the A/C compressor case and the alternator case coated matte black. For some reason the A/C case is a little bit shinier than the rest of the stuff, kind of a sheen black or semi-gloss, but it still looks nice and I'm happy with it. My friend is going to show me how to rebuild it and put all new seals and such in it. I also need to get a 15/16" socket cut down on a lathe so it will fit in my tiny overdrive alternator pulley so I can tighten down the nut. I think I might powdercoat the nut matte black too. We'll see. Anyway, here's what we're up to so far...
More to come when I have more time.
Paul.
Dalamar
SLC, UT
Re: The SBF 306 Engine Build - Updated 04/20
Looking VERY good Paul.
Kornnut
Looks great :thumb:
P
Paul
I'm going to find some good looking black or grey plug wires, order them, and cut them to fit so they look perfect. Maybe I'll write up a tech article for those of you who want to learn how to cut and fit plug wires.
Paul.
mich_666
where are you ordering your fasteners from? Im going to be starting a similar build pretty soon....
Nice build! :thumb:
fastgtfairlane
hey paul, how much would you say you have invested money wise in your engine? this would be a great comparison to the 4.6 build thread. how much power are you expecting out of this engine?
P
Paul
Most of the parts in this engine came with the car, so much of the actual costs so far have been new rings/bearings/gaskets/powdercoat/fasteners/rebuild stuff/etc. I've also bought a bunch of used parts which I've refurbished. Most importantly, this has drifted away from its original intent and is NOT a budget build anymore. Most people don't spend $600+ on bolts.
I'm expecting about 270 rwhp N/A.
My fasteners come from www.totallystainles.com
Paul.
Suspect
ATL
where ya get the water neck from? also what distributor is that?
looking good! going alot faster than mine. :(
P
Paul
Water neck is CSR.
Distributor is stock.
thorco3
IN
can't believe I never checked this thread out. Everything looks awesome Paul :happydrunks: I can somewhat relate to all the sanding on difficult parts like that intake. I don't have anywhere close to 100 hours in mine, but easily in the double digits.
P
Paul
Wow! It's been a long time since I actually worked on the notch. Things at work have been hell, but that's all over now so I should have some more time to get the car done... just in time for 100+ degree temperatures! :nonono:
Anyway, I posted in another thread that I picked up a used tubular K-member and A-arms from a buddy of mine. He was parting a car out and I got 'em for only $250! :dancing6:
http://www.sn95forums.com/forum/index.php?topic=26406.0
Well, as with anything used, sometimes you need to improvise a bit. The bushings were TRASHED and needed to be replaced. However, I have no idea who manufactured these a-arms, or how I would get a set of bushings without going through too much trouble. Thankfully, a good friend of mine is an engineer and CNC machinist. He's got a pair of CNC mills in his garage.
So I went to his place and asked him to make me some bushings. He grabbed some delrin (basically hard plastic) off the shelf that he had laying around, and started measuring things. Before you know it, he was cutting the a-arm bushings. Here's a picture and some video. Sorry for the quality - I took this video with my phone.
The bushings before the backs were machined off - they're square! :banana:
...and the video of the CNC mill in action:
http://members.cox.net/carpinteri3/A Arms Bushings Machining Movie 2.3g2
He even made me a set of delrin steering rack bushings while he was at it. Everything is flawless and fits perfectly. :)
Tonight, I decided to assemble the a-arms and k-member.
First, I cleaned up a spare set of nuts/bolts that I got from a buddy of mine. They looked pretty bad.
...much better.
Here's the sleeves and finished delrin bushings.
Here's the A-arms assembled. If you ever do this - DON'T FORGET THE GREASE!!! They'll squeak like crazy if you don't grease them. :)
After some "convicing" (read: sledge hammer, pry bars, impact wrench) the A-arms agreed to seat themselves in their new home. It was no picnic getting them to fit, but they work like a champ now. :) I seriously doubt they are from the same manufacturer.
Here's my "negotiating tools":
And here's the assembled k-member! :thumb:
So up next, I've got some powdercoating to do... I have a set of brand new SN95 spindles to coat. I plan to assemble an entire new front suspension off the car, and just swap pretty much the whole thing for the stocker. I'll have all new urethane and delrin bushings, bumpteer-adjustable outer tie rod ends, SN95 brakes, coil-overs, flaming river steering shaft - the works! It should make the car handle MUCH better. It was positively scary before. Seriously.
I also need to finish up some stuff on the motor. I'll post pics of my progress as it moves along.
More to come...
Paul.
thorco3
IN
Re: The SBF 306 Engine Build - Updated 06/11
tubular k and arms look pretty slick, sounds like a pretty awesome setup too.
alleghenyamerican
