Venom 's Build Thread
V
venom
One of the things I regret selling is my engine lift years ago. When getting an engine stand don't get a cheap one that has 3 wheels as it many a bit unstable with the large dohc heads.
V
venom
Removed everything,now starts the long process of seeing what needs to get done.
This tranny jack is great.
Got engine out with my bikes still hanging up from above.
These heads are huge.
Centerforce clutch
Tranny jack is also great for moving it around.
Empty engine bay, needs some cleaning
V
venom
Cleaned up the t56.
Got some painless powerbraid and relay kit.
Went to my builder and he discovered as I expected some issues. Piston to wall clearance was too much. He said looks like whoever build the block did not do a good job. As you can see there is oil everywhere. Currently I have 18cc dished Diamond pistons. I will probably go with 5cc dished to get compression up from 8.1 closer to 10.1. This is high for boosted pump gas however for e85 it will not be a problem. Since compression will be bumped up it will add much needed power down low.
V
venom
Flywheel has new insert and ready for balancing along with crankshaft. When installing new insert make sure to torque to 5 ft lbs or 60 in lbs according to Fidanza. Nuts are oval locking, no loctite.
Old insert was in rough shape. Good thing about these flywheels is that for around $55 you can replace insert. For drag racing a steel or lightened steel flywheel is better but if you want something that revs quicker aluminum is what you want to get like for a track car.
V
venom
Thanks, things are going to pick up once I get the crank back. This is the reason I am redoing/checking everything myself as it may take me some time but at least I know it was done right. TOB missing nice size chunk? New HD Ford TOB. Should be picking up my Promotion Blue 750 plate and disc within a few days.
V
venom
Picked up my Promotion Blue 750 Clutch kit. Let me just say that customer service cant get better than the people at Promotion. Here is the Spec pressure plate. The clutch disc has kevlar on one side which may explain why so many say that the Promotion setup is the best single disc setup they have had.
Back side of plate, notice the CF2 surface.
Here we have the pate side of the disc.
Flywheel side.
26 spline alignment tool. If you perform a t56 swap you will need to wire a switch to activate the solenoid which sits next to the shifter. The solenoid is used to prevent from accidentally shifting into reverse. Since non t56 cars do not have this feature a switch needs to be added to activate the solenoid. I will get into this later in the build.
V
venom
Well it took 9 weeks but finally got my pistons. MMR custom Manleys and notched for cams. Going to drop it off at machine shop so they can get bob weight for balancing the crank shaft. I am also going to order a custom camshaft but hopefully it will not take 9 weeks lol.
Venom, much respect for doing all this yourself. your doing an outstanding job!
your car looks great.
I cant believe I haven't seen this thread b4....
When your done are you available for hire?!
V
venom
wow. that piston looks like you could eat off it.
Too bad you will not see it.
Thanks but I really didn't have a choice. I would of preferred to hire somebody to do it but I've been let down so many times. I realized that shops are no better than doing it yourself as long as you get educated. Best teacher is google ;)
Looks like Jesus Chris hand crafted those himself.
“Most assuredly, I say to you, he who believes in Me, the works that I do he will do also; and greater works than these he will do, (John 14:12 NKJV).
If this is the case then praise to God.
