you think that makes you nervous you should have seen me cutting my cf hood to install the flush aerocatch latches.
Swapped out the incorrect steering wheel hub for the proper part! Big thanks to @vtchopperdude for doing his home work and sharing the knowledge with the rest of us.
Just look at that gap!! The bolt had, AT BEST, 2 threads in the column!
heat will not do anything to cf to help you move it. short of having some lean on sections while you tighten up the bolts in the door jamn I am not sure what can help.
315s up front you gone cray cray now... Do you need rack limiters to keep them from rubbing inside?
Is that a factory Cobra hood or aftermarket?
Nice. I have an aftermarket fiberglass Cobra hood, but I'm not sure if the grill inserts will work in it. I'm guessing they would, looks to be the same. I'm not sure mine has the "hump" in between the nostrils either - I need to look closer at it honestly. I just bought it a few weeks ago and don't have it installed. I'm not going to install it until I get the car painted in a few weeks.
