White's '95 GT "Unicorn"
white95
white95
Apex Junky
Prairieville, LA
This came together nicely!! Just need to install my Aerocatch latches and it’ll be complete.
2B282BB1-BC7B-40CD-ACBD-12FB05A7C272.jpeg1F29B06B-A815-4888-9A45-A7FC67946D53.jpegD0680485-A96C-4FFA-93C5-0823FD8C013F.jpeg
white95
white95
Apex Junky
Prairieville, LA
I am more than pleased with the results and I can’t wait to find out how well they reduce under hood temperatures.
This picture is amazing because you can see the CF intake tube. Totally infatuated with this car.
Anyone else have custom seat covers for their Corbeau buckets?
Correct. I’m using a C6 Corvette fan controller (PWM) and it’s a two wire hook up using the high speed winding.
looking at how that plug melted either some resistance built up over time or there was just too much current being pulled. I wonder if the low speed wire stays on while the high speed is hot as well to help supply enough power?
white95
white95
Apex Junky
Prairieville, LA
I’ll have to look back through my notes/videos but it wasn’t pulling very many amps. Apparently this was something that was common on 100% stock cars and Ford even issued a TSB.
The low speed wire no longer exists. The possibility of it being a loose connection that caused heat is a possibility due to the stupid tabs being broken off. Hoping to remedy this all very soon with aftermarket market parts.
I had a folded piece of cardboard stuck beside the connector on my car when it was stock. The fan wouldn’t run without the cardboard because the connection was bad.
white95
white95
Apex Junky
Prairieville, LA
Coming soon:
MMR/MM oil filter relocation (Thank you @lwarrior1016) with a few stainless brackets to make it unique.
CF125182-7715-48B0-AB9E-3EB704151DFA.jpeg59CC4F97-6EB7-42AC-A2FD-80949A04DDC7.jpeg381F60FE-14BF-4CE7-A13C-EF64DE883280.jpeg
Motion Raceworks catch can:
white95
white95
Apex Junky
Prairieville, LA
Fixed my stupid fueling issue by changing this vapor relief vent.
Discovered the exhaust had been contacting the suspension long enough to beat the piss out of the tailpipe. This is justification enough to modify something.
Made some adjustments to the panhard bar to cure driveline vibration and to change the handling up a little. It seemed to work on both counts as the vibes are down and the car feels a little more eager to rotate.
Time will tell.
Still daily driving the car.
BA1034D0-AF5E-4864-B533-0B39F09EA0B9.jpegE5986B97-F7D8-4C4A-9224-A09D84F703A6.jpeg9B815DDD-7FE1-4CBF-90A7-65B1CBC7CBD0.jpeg
white95
white95
Apex Junky
Prairieville, LA
Haven’t had much time to mess with the car lately but I will be building a new AC wiring harness from scratch very soon. I’ve never had a functioning air conditioner in this car, ever.
white95
white95
Apex Junky
Prairieville, LA
Not much to see besides a dirty engine bay but I’ve installed the new AC lines. Going to pull it under a vacuum tonight and begin building the wiring harness.
Suprasuavy
