1997 GT build..updated Oct 2011
Re: 1997 GT build (time for the motor)
nice build you have going here Chaz.
Body work looks good, and I like the "STANG" on the rear cover.
C
chaz
Draper UT
Interested in what your few extras are because I did the swap and will be dynoing soon... just want a comparison. Thanks brotha, and looks great man. Nice work.
99 4.6 block, forged pistons and forged crank. 10.5/1 CR
Windsor PI stock heads and cams
PI Intake
Stock throttle body Ported and Polished
Intake
Log Tube Headers
BBK X Pipe
C
chaz
Draper UT
Picking up a newer tranny that has 90K and has a shift kit, I will be adding a high performance torq converter to it and putting that in
After this is done I will be rebuilding the rear end then adding a little 125-150 shot
KWClutch
Nice build. Needs different rims ASAP!
C
chaz
Draper UT
Dalamar said:
Where are you getting the convertor?
Not sure Im having Travis call the shots. I think I will go with a 2700 stall with a progressive 150 shot
good call, I went through travis to have mine made.
C
chaz
Draper UT
Update, this last weekend I got some new wheels for the stang just in time for our local cruse.
Also coming up this week is a rear end rebuild and the new built trans and stall are going in the car.
275s in the front and 315s in the rear
C
chaz
Draper UT
Re: 1997 GT build (almost time for the track)
This week its getting cross drilled rotors and new pads.
Next Monday its getting the built AOD with a 3000 stall put in and the rear end rebuild along with an aluminum drive shaft.
98GTnSC
black 10th anniversary cobras. same wheels i have. keep it up
C
chaz
Draper UT
Built trans is in with a 3000 stall
Also rebuilt the rear end and went to 373s from 410s. This was a good call since with the stall I burn the tires in first and when it shifts in 2nd it spins again..
Picking up A Vortech this weekend
95rioredcobra
Nice build... Just so you don't go to far thinking you have a Cobra crank without actually verifying that fact... Some 99-91 Automatic GTs came with an 8 bolt cast crank from the factory so just be safe. Great job so far good luck going further!
C
chaz
Draper UT
Added a V1 Vortech Supercharger. Just added a new Pulley no numbers with new pulley
HP with old pulley 389HP on 5.5 lbs of boost
Oh yeah also added some 27X10.5 MT slicks for the track
Re: 1997 GT build NEW Vortech SC added
nice man!
what psi will that new pulley give ya?
C
chaz
Draper UT
Last year I had a PI motor 10.5/1 CR with a Vortech SC pushing about 6lbs making just over 390hp
Beefed up 4r70 trans
12.7 1/4 mile
C
chaz
Draper UT
A Lot has changed from last year to this year
Took my car in to the shop in April to make some changes and just got it back, this is what I ended up with
Aluminum Block, Forged stroker internals, 4v cobra heads with stock cams.
Modified on 3 turbo kit with a Bullseye S366 B.M.W. turbo
Fully built 4r70 with trans break (capable of handling 1500 hp)
New rear end with 31spline axles and 355 gears
First time on dyno car made 633hp on 14lbs of boost.
The next few weeks we will be running some test on it and fixing a few exhaust leaks and see if we can add 2-3 more pounds of boost.
Not to bad for an Auto car with a 66mm turbo
