97 GT Finally Dynoed, make comments NEW(VIDEO)
cobraclone
ok my mod list is as follows k&n Intake , ford 70mm throttle, c&l intake elbow, under drive pulley,EGR Delete, custom ground kit , full 2.5 off road exhaust with flows, and 3.73 .
this combo did 211 RwHp with 265RwTq .can somebody tell me if my car is leaning out?
NXcoupe
Re: 97 GT Finally Dynoed, make comments
Ok, it's too rich. You see on your torque graph, where the line looks like a little kid drawing mountains? Well that is probably your plugs misfiring because they are getting a very rich, nearly 12 to one a/f ratio. It could also be detonation, but I can't tell that because I wasn't the one dyno'ing it. It's something you hear, and just feel on the dyno. I believe with that a/f ratio, that there is still some power left in the tune. How much advance was it data logging? What advance was in the tune? What software are you using?
C
cobraclone
actually it was just a power and A/F dyno so later on i can get it tuned, but for now that chart is not tuned
hottwheels04
deff needs a tune, that graph is all over the place, be careful dont beat on it until its running good and tuned, those numbers are very low, my 95 gt dynoed 201rwhp with no mods, so u deff have more in it for power deff prob 215-230rwhp or so
97mustanggt
deff get it tuned will make a whole of a diff...if im not mistakin your 3rd graph on your dyno sheet it your a/f you want it closest to the line in the middle that they way all my sheets look like all are on the dotted line in the middle and they way it looks it is runing way rich..lets us know how it goes when you get it tuned
C
cobraclone
from what i heard , here in puerto rico since its so hot and humid those numbers are good for a non tune , check out temp 103 and humidity 32% ether way i sent the graph to the person im gonna buy the SCT tuner and ask him to make a tune based on the dyno.
97mustanggt
are you gonna put your car on the dyno? or download a tune on to a programmer then on to you car
97mustanggt
ya but every car is diff..if it was just a base tune then all that is so you car will run with your mods but still need to get it on a dyno to have a true tune for YOUR car
NXcoupe
I doubt it is a custom tune, who is it coming from? Anyway, the heat and humidity is going to lower hp for sure, but in a hot, humid climat like you are in, you need to be leaner because the air is thinner due to the heat and moisture in the air. Less oxygen, means less fuel is needed. Just a suggestion.
C
cobraclone
What about the second run . isnt the A/F way lean on the graph?
NXcoupe
I see what you are saying, but that car wouldn't run at that a/f ratio, that had to be a wide band 02 sensor going bad or something. It would have rattled/detonated itself to death. I can only assume that.
C
cobraclone
wheew thanks for clearing that out.
Blk97GT
to give you a comparision my car was on the dyno last month and with these mods....
PI intake
C&L plenum
C&L intake
high flow catted H
Mac catback
3.73's(not that it matters on the dyno)
My car made 211/260
Now im still running the stock TB, no under drive pulleys, catted H and no tune.
My buds 97 with just pulleys, K&N intake, O/R X and flow catback made 214/281 on the same dyno right after mine was done. Every car is different and these NPI cars dyno stock anywhere from like 175whp up to 195-200whp. Its a wide range and it just depends on your car, I think your about where you should be.
karrarararararar
sounds like he got a factory freak
