Snorky
- Joined
- Feb 10, 2022
- Messages
- 837
- Reaction score
- 711
You mean like a vanity plate? 4BDNFRU? 10cyl? 6.8LITR?it begs for a name for sure, maybe a custom badge as well. 10-port stang?
Awesome, ill keep that in mind. The only thing that popped into my mind was just a simple Triton V10 badge on the trunk lid. Or 2 on the fenders where the GT badge goes.vanity plates are cool but I can make a badge out of aluminum to go somewhere also.
"Another problem was the lack of a suitable engine controller. Nothing in the Ford bin was capable of running the odd-fire V10. So, they couldn't just wire it all up to a single EEC-V computer from the 6.8 V10 (an engine that uses a split-pin, even-fire crank with balance shaft). But, the EEC-V was capable of running an inline five-cylinder engine, so they decided to use two EEC-V processors, one for each side of the engine."^ yes
And, if i remember correctly, didnt they use 2 fast EFI systems set up for 5cylinder tuning?
Thanks man! i was pretty nervous shaving those valve covers since they are NOT readily available like mustang ones. Haha, now i might have to shave my 4.6 covers too since they are off the car.Looking good.
Haha thanks for following it, i was chatting with the machine shop today, making it my goal this week to pack up the rotating assemly to have it balanced.Glad I found this thread, looking forward to seeing it complete. I was literally thinking of this exact thing when I got my '99. But I have limited funds and already have a 351W block... so I'll be doing something more boring while living vicariously through you.
I know I'm late to the party on this comment but with my 5.4 swap and using a bbk tuned length shorties and bbk hpipe, I didn't have to add any extra nor did I have any clearance issues other than some minor dinging of the headers for passenger frame rail and steering shaft. I also stuck a 4.10 in my rear end and I feel that I could grab some traction through first if I was on a track but definitely just spins through it on the street. my nitto 555s hook up pretty well after the 1-2 shift. *edit should be noted I'm running a BMR kmember on solid MMR mounts and 1 inch kmember drop spacers off of ebay.Interesting!
The exhaust is a pain. With my 5.4l i took a jegs H-pipe and extended the drop from the manifold mounts and added extra to the H pipe itself. Im sure any exhaust shop can handle this or a full exhaust build.
With the 5.4l, 3:55 rear gears is as deep as i want to go. The off idle torque from these naturally aspirated engine is phenomenal. Same goes for 5th gear driving. Their is no reason to gear down to gain speed.
Better late than never!! did you put the headers on the engine in car or did you do it pre installation? And did you install it from the bottom or from the top?I know I'm late to the party on this comment but with my 5.4 swap and using a bbk tuned length shorties and bbk hpipe, I didn't have to add any extra nor did I have any clearance issues other than some minor dinging of the headers for passenger frame rail and steering shaft. I also stuck a 4.10 in my rear end and I feel that I could grab some traction through first if I was on a track but definitely just spins through it on the street. my nitto 555s hook up pretty well after the 1-2 shift. *edit should be noted I'm running a BMR kmember on solid MMR mounts and 1 inch kmember drop spacers off of ebay.
I installed from the bottom, fully assembled, headers, trans, intake, hpipe all installed before putting it in the car. Wasn't too hard and did it by myself. Im glad i went tubular as the mounting holes in the bmr kmember are slotted left to right so you can offset the front assembly if youre needing clearance, You're gonna be super limited on header options for sure so it's likely gonna be a "buy what's available and cross your fingers" I'd look for whatever exhaust keeps it up tight to the headers the most. Kmember spacers give you all around clearance except the steering shaft which is gonna be a PITA regardless.Better late than never!! did you put the headers on the engine in car or did you do it pre installation? And did you install it from the bottom or from the top?
i am weighing out the option of a tubular K up front for the space, not too concerned about weight, although that would be nice to offset. I have been staring at v10 headers online. I see some DNA shorties online. As well as some longer headman headers.
These are the "DNA" ones.. i feel like they will be challenging to fit eith the frame rails.View attachment 16180
These are the headmans.. something tells me they might be easier to fit
Any thoughts?
