My engine rebuild thread!
Zutz23
I have a 2v engine sitting. I m dying to forge it and drop it into my car.
Daryl
Daryl
Somis, CA
So here’s the final dyno numbers. All said and done I gained 70 ft lbs torque and 40hp. Needless to say I am severely disappointed given all the time, work and money I’ve put into it to arrive at 267max torque and 202 max hp. But that’s how Cali-fucking-Fornia with the FOUR cat requirement on this car fucks you I guess.
The dyno guys knew I was disappointed and informed me of an off-road H-pipe that, if I can get one in CA, is a direct swap R&R for the cat section of my choked down, gagging exhaust.
Staff member
Man, I’m not sure the cats are going to get you 100hp. Those are stock kind of hp numbers. I’m upset for you.
thats no joke I had mine put on a dyno during a dyno day when it was bone stock and it was 187/250 I thought. That was with stock cats, stock air filter, stock everything. Its been a while what was the build list again? Is it running reliably now at least?
Daryl
Daryl
Somis, CA
Yeah, it’s running great now. No dying or spun rpm’s, thankfully, as that was embarrassing though no fault of my own. Think I’m just gonna run it as is and enjoy it for what it is! :)
Daryl
Daryl
Somis, CA
347 stroker: Scat rotating assembly; AFR 165 CARB-approved heads; Comp cam
something isn't right imo but I am not an engine expert by any means, still working on my youtube cert. Where is black?
joemomma
Yeah that seems really low. Again, I'm no expert, but I play one on the interwebs from time to time. With a 347 with that H/C/I you should be pushing over 300w. The heads may be holding you back a little, but not 100hp. I agree with the others, something seems amiss.
How does it feel driving? Is there another shop around you could book some dyno time on? Maybe their dyno is whack.
Daryl
Daryl
Somis, CA
At work until 1:00, then errands. Will gather info and field questions, etc. Stand by!!
joe65
wow, yeah something's not right. just the heads alone should wake up a basic 302 but a 347. tune is not right. Sorry but the cats don't choke a na that much. I've gone from the stock 4 cats on a mach 1 to an x with 2 cats and it wasn't a noticeable difference except sound.
TrickVert
Woodland Park, CO
The stock cats actually flow well*, so unless your cats are cooked, that's not likely your problem. I agree that there's something else going on. My HCI 302 with GT40P's made 272 RWHP and 302 lb-ft TQ before the Vortech was installed.
*From THIS FORUM ARTICLE - Super Ford, May 1996:
"Before proceeding with our exhaust modifications, we wanted to try a set of off-raod pipes with the stock headers and mufflers. Off-road pipes, which bolt in place of the factory catalytic converters, are not street legal, but many 5.0 Mustang owners bolt them on for the drag strip or road course. So after our Phase 1 bolt-ons and before discarding the stock headers and mufflers for Phase 2, we slipped in a set of off-road pipes from Pacesetter. We immediately noticed a more high-performance growl from the stock mufflers. On the Dynojet, the off-road pipes picked up 5.5 horsepower."
TrickVert
Woodland Park, CO
Daryl: I just thought of something - Where do you live (altitude), and were those readings actual or corrected for sea level? Mine were corrected values. Actual here is probably 25% lower.
Daryl
Daryl
Somis, CA
What would be a good size injector to run given my set up? If memory serves from reading an earlier worksheet invoice, 42# comes to mind.
honestly if the injectors were holding you back the tuner should have been able to see that and then try to sell you the parts. 42 lb would be more than enough but you will need another tune for them :( or a maf that is made to work with them. The maf can work but if we are already suspecting problems I am not sure I would say to go that way.
TrickVert
Woodland Park, CO
My N/A combo above was using 24# injectors. According to THIS CHART, 32's should be adequate for yours, but 42# squirters could be tuned in OK as well. Also according to that chart, my 42#-ers should not be enough for me now with ~ 475 HP (corrected) at the motor, but they're no problem. Of course, at sea level, maybe they'd max out. I'll have to remember that. Knowing what I do today, though, I would've gone with 60's.
Staff online
