Brian95SVT
I'm going to have to start making a list here soon......
Yes they do! There was supposedly a recall sometime in 97 for an upgraded radiator. Ford changed the radiator design because of the 96 issues.justinschmidt1 said:my96gtstang said:i will end up getting a trans cooler and a new radiator just to get them newer and running things cooler. my car randomly seems like it's hotter than it should. i will prolly get a 180 stat as well
Dont the 96s have a radiator problem?
my96gtstang said:So just got with that mitlkasjdkfj one?
J.R. said:voidfinger said:J.R. said:That's what everyone thinks, although I'm not the only trans guy that will tell you that.
well if i would have known it when i did it and had the extra money which i didn't i would have done it...
would you say that the little that was in there would mess it up?
Honestly, it's hard to say, but probably not, but you are going to change the fluid and filter when you should, most people won't. They think it's a money making scheme or something, go 130k, then it finally starts to slip, they drive it getting worse and worse, then flush the thing. Then they say flushing the trans killed it :hammer:
In the end, some of that crap is in there anyway, no way around it, that's what the magnet is for. BTW, you can put a bigger magnet in there if you want to catch more junk.
J.R. said:Bottom of the pan. Never heard of the dyno thing, doesn't seem any different than normal brakes. Of course I have seen dyno operators do goofy thing's like cut the ignition immediately after redline and whatnot too.
J.R. said:Yeah, it seems kinda feasible, but that would be if they just locked the rollers, and even then it would only happen for a split second. There are bypass ports in there to prevent pressure spikes. I dunno, I need to think about it more.
my96gtstang said:what was that link for the 3500 stall again?!?!
i'm trying to find one with a price so I can make this list...
unless you can send me to like summit and find one but i didn't...
Zwolaver21 said:would this cooler be good I have a 3600 stall? http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM-70264&N=700+115&autoview=sku
