White's '95 GT "Unicorn"
white95
white95
Apex Junky
Admin
Prairieville, LA
So once that was sorted, I switched to the pedal. All was well until I went in on my back, turned some and got stuck :rolleyes:
At first the wire going to the pedal was a little short. Had to mind F this and wound up routing things behind the blower motor along the firewall.
white95
white95
Apex Junky
Admin
Prairieville, LA
It’s alive-ish.
Apparentl, I goofed the crank sensor plug install and the crimp wasn’t making good contact. Soldered longer wires to the existing pigtail and tried again. Success was achieved.
Wrong MAF was included with the control pack and O’Reilly had one.
Stuck injector dumped enough raw fuel the exhaust to form a puddle under the car. Stressed my three brain cells to the max but got a good buzz for a bit. Swapped to some GT500 injectors I picked up from Lwarrior awhile ago. Problem solved.
Except it seemingly killed both oxygen sensors and I’ll replace them tomorrow.
white95
white95
Apex Junky
Admin
Prairieville, LA
How involved IS it to install a Holley ECU/wiring etc
Not the end of the world, but there is some in-depth aspects to it. I deleted the CCRM so I had to complete the starter circuit, add some wiring to the power circuit so the passenger turn signal would work, added a relay/harness so the AC would work, added a standalone power steering set up and since I’m using an LCD display that runs off of canbus, I didn’t have to mess with the gauges.
I give it four out of five wrenches.
