Cheapest 500hp build
I
Itsaiight5.0
Was asking $330 shipped. It will cost you way more than that to get a new one shipped straight from team z.
Ok. Well the heads he already ordered and "they are supposed to fit", so in the case that they don't, I'ma be sending you some money hahaha
Sent from my Moto Z (2) using Tapatalk
evilcw311
Most Evil Member!
Louisville, KY
Is it the whole assembly or just sub?
evilcw311
Most Evil Member!
Louisville, KY
I'm guessing that's tha whole..?
This is the entire cradle. It bolts up to the bottom of the front frame rails. Motor mounts and motor mount to it.
Like I said though, you’ll need tubular a arms. I have upper spring perches if your going to use traditional springs instead of coil overs that I’d throw in for free.
I
Itsaiight5.0
Yea I'm outta my wheelhouse here. What all will be needed that I don't already have, or that comes with what you got?
evilcw311
Most Evil Member!
Louisville, KY
Mainly the tubular a arms. If your not gonna use coil overs then you need to get a arms that are provisioned for springs. If your doing coil overs then you just need to pick what ever a arms you want
You’ll need to make sure your using the correct motor mounts for a pushrod motor. Aside from that everything else will bolt up.
I
Itsaiight5.0
How do u feel about egr delete? Some sat it hurts, others it doesn't. Whatcha thinking?
01yellercobra
If its functioning leave it alone. If it's broken and you don't have to deal with smog or inspections pull it.
I pulled it from my 01 that was pretty far from stock. I kept getting a code after I installed headers and got tired of it. So I yanked everything out and turned it off in the tune. Being a self tuner makes things like that easy.
Now my 04 still has it. Well, had it until I went stand alone. It doesn't hurt performance and helps with MPG.
I
Itsaiight5.0
So another question if anyone has some input, when do you need to start upgrading radiators? Mine came with an aftermarket radiator, but it sat for close to 2 years and wasn't flushed, just reinstalled. This happened the other day but it never overheated just got a lil warm around 210°. Hoping it ain't a blown head gasket but I won't know till I get it back in the shop.
07GtS197
Fort Myers, Fl
Why is it goopy like that? Ive never seen a blown head gasket go that but who knows. Also did you bleed the system after it was reinstalled?
I
Itsaiight5.0
So on the real, do I need an aluminum radiator or will a plastic one do fine?
