Re: STROKER ENGINE BUILD --update-- Longblock is Assembled
so I will give you my motor mod list I still need a tune if this doesn't go right i will be seling the short block and be buying a stoker too.
origional romeo block bored .030 over 285.67 c.i.
clevitte stand size rods,main bearings
Ford racing high volume oil pump
Moroso 7Quart oil pan
Felpro gaskets
speed pro 10.50cc pistons
P.I. heads and intake
comp cams 274h .550 lift cams
comp beehive valve springs
C.R. 10.25
Flowtech 1 5/8 LT headers
Prothane Motor mounts (this was a great upgrade)
Ford rAcing 9mm wires
screamin demon coil packs
bbk 75mm throttle body and plenum
k&n Fipk kit
Pro-mass 85mm maf meter
Ford Racing 30lb injectors
kirban fuel pressure regulator
summit 190 fuel pump
my origanl sct tuner with old programs (will be getting reprogramed when dynotuned
pypes o/r x-pipe with flowmaster 2 chambered muffler
thats it on the motor I belive I got a lot of other things done I am pretty sure I am over 300rwhp n/a but won't find out untill I get tuned
