My little Pony
lilj4u2njoy
Forest City, NC
Well I decided to ditch my other build thread and focus on this motor build. I was going to do a simple HCI but decided against it. SO i called up Fox lake and have them do me up a 306 short block, and after about 6 weeks i just got it yesterday. But before the pics, this is what the motor build will consist of.
-GT40 x303 Aluminum Heads
-SVO 1.6 RR
-TFS Intake
-TFS Stage 1 Cam (degreed)
-All new TFS lifters
-Comp Cams Timing chain
-Melling oil pump with arp harded drive shaft
-All arp Hardware throughout the motor
-FRPP 24lb'ers
-70 mm Pro Products TB
-76 mm c&l maf
okay enough rambling heres what i got so far
BruhBrahBrad
Just a question, why a red block? seems like it would clash with your car, and it reminds me of chevy lol.
lilj4u2njoy
lilj4u2njoy
Forest City, NC
Thanks, well I have been tearing off a few things like the accessories and I busted up my knuckle pretty bad and had to get some stitches so now my hand is so swollen I can't grip a wrench so I will take a few days off from working on it, but basically I have everything to put this together except for a harmonic balancer which I'll buy this week
Musturd
right on dude shitty about your hand but this should be a nice build for ya what kinda compression is it going to make.
Make sure all your oil galley plugs are in there, my shortblock was missing one I didn't find out until I started it up and my HV oil pump could not produce any more than 10psi of oil pressure. Had to tear it down again.
Also, did it come with an oil pump? Get the builders recommendation on what pump if you have to get one, another lesson learned for me.
lilj4u2njoy
lilj4u2njoy
Forest City, NC
he told me a standard volume pump would be fine, i went with a melling. Ill make sure all the oil galley plugs are there tho, if they arent where can i get them?
lilj4u2njoy
lilj4u2njoy
Forest City, NC
not sure on the compression, thing is, i know how motors work and how to assemble them but the diagnostics part of it im clueless... how can i check and see? is that something the machine shop would be able to tell me?
Musturd
Yea ur machine shop should know. My guess would be somewhere around 9.2-10-1compression
I'd just call the builder, I'm sure they'd send some if they forgot. I bought a set of freezeplugs for a 5.0 and it had the oil galley plugs in the kit.
CC'S95GT
Hampton ,Ga.
well since your not working on the engine because of the hand injury. How some pics of the stitches? You know how it goes around here, "pics or it didn't happen".
