White's '95 GT "Unicorn"
white95
white95
Apex Junky
Prairieville, LA
Moving along with the wiring. So far I’ve gotten the knock sensors connected and I’ve moved on to the IAC and TPS.
Switched power that remains constant during cranking.
All splices are soldered and covered with heat shrink. This was the constant power that goes to the distribution block on the battery.
Fuel pump relay and related wiring.
This is still a mess but I refuse to make any battery connections until I’m ready to start cycling power systems.
Does anyone else sign their work area? I do. This is the route for the battery relocation wiring and the Holley power.
Holy CRAP... It goes into the body :eek:
1F8B8F8F-BCB1-4636-8133-521955218067.jpeg 92612CBE-4D15-44E6-8E1F-5C593FEFB8CE.jpeg
The knock sensor wiring was as simple as removing the sub-harness and connecting it to the HEFI harness.
The aforementioned IAC and TPS wiring will run underneath the intake and, once the connectors are swapped, will be a very clean install I think.
Werecow
Virginia
Very very nice!!! All that hard work will pay off in the end! I'm sure as much attention to detail as you're taking all should go well!! (Figners crossed for ya!!)
I would suggest moving the wiring down closer to the seat on the side than towards that plastic panel. The panel is held on by those torture devices that slide over the pinch welds and then have teeth to grip the metal. They can grab a wire as well
white95
white95
Apex Junky
Prairieville, LA
Need to add four new wires to the J1B connector for the new IAC and then it’s just a matter of activating it in the software.
I’ve forgotten what a semi complete interior looks like. Can’t wait to be “finished building” so I can clean and paint the interior and body!
white95
white95
Apex Junky
Prairieville, LA
Good point.
Werecow
Virginia
Boostr1
North Jersey
It will withstand a nuclear explosion...
white95
white95
Apex Junky
Prairieville, LA
Small but meaningful progress today. Pulled this triple gauge panel out for @lwarrior1016 sinxe he traded me the lower radiator hose I needed for it.
Found out this random connector I’ve held on to fits the TPS sensor in my new throttle body.
Connected the Holley input wire for the HVAC controls and that’s about where I’ll stop today.
This how the Holley will control my AC, for those interested:
EdgarR213
