Rendered my fuel gauge useless by losing the vent plug. It popped out and went straight into the hole in the frame rail. Removed the adaptor and connected the sensor directly to the regulator.
Unicorn 1 / White95 0
Wasn’t registering any fuel pressure so I decided to reverse the fuel pump polarity. Still no pressure. Removed one of the return lines and ran a line into a gas can to see if there was any flow at all. There wasn’t any. Reversed the fuel pressure back and nadda. As a reach, I put about two more gallons in the tank.
Bingo. 30 psi. Made a few adjustments and left it around 43 psi.
Unicorn 2 / White95 0
Let’s see... Once I sorted that shit, I turned my focus back to starting this bitch. Which hasn’t happened. I’m losing power to the ECU while cranking. Seems the circuit I chose in the ignition tested good for continuity with the key on and the key in the start position BUT when testing with voltage, it drags down to mV. This is why my dash flickers on and off while cranking since it has can bus power. I even bought a Tick Performance DDPM to prevent this.
sigh..
In troubleshooting this, I discovered that I somehow left the nut for the main ground off. This helped but not much. It did spin the starter faster so voltage drop was lessened!
Pyrrhic victory.
Unicorn 3 / White95 0
Decided to connect the switched power lead to a constant source and try this again. I’m having issues with the cam and crank sensors starting as it’s not registering RPMs while cranking. More work to do..
Unicorn 4 /White95 0
